Results 1 to 7 of 7
Thread: Silabs USB FM tuner problem.
    Low Bitrate rcubed3r's Avatar
    Feb 2007
    Salisbury, NC
    My silabs works, but I do not have any audio out of any speakers except the front. My rears and sub do not play at all. Winamp and everything else plays on all speakers.
    Even if I am not in RR, I only get sound from the front when I use radiator.
    Any ideas?
    Thanx,
    Ron
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Install and use the Line-in plugin option in RR Config -- it MAY help.. but this just depends on your speaker setup.
    Ride Runner RR's Myspace
    Feb 2007
    Salisbury, NC
    OK, I'll try that tomorrow.
    What would I enter in the box after 'use line-in plugin:'
    Thanx,
    Ron
    guino's Avatar
    Nov 2004
    Toronto, Canada
    leaving it empty should work as long as the config doesn't save lineinpar= to RR.INI.. anyway, you can try the default or play with the settings:
    line://title=Radio,srate=44100,bps=16,nch=2
    Feb 2007
    Salisbury, NC
    Using the line-in plugin works to a point....
    I still only get front speakers if I leave the line after the checkbox blank.
    If I fill it in with the default settings (as above), I get sound form all speakers (!), BUT there is an echo, BAD!
    I can't tell if the rear speakers are lagging, or the echo is just in the stream itself....
    Any ideas?
    Thanx!
    Ron
    guino's Avatar
    Nov 2004
    Toronto, Canada
    To prevent the echo, simply mute the audio line in windows AND make sure you don't set RR to mute/unmute that audio line when stopping/starting the radio.
    Feb 2007
    Salisbury, NC
    Quote Originally Posted by guino View Post
    That doesn't help, in fact it does not make any difference. I noticed that the 'echo' gets progressively worse as the radio plays. It is like I have two feeds, and one is playing a hair slower than the other one. After about 20 seconds it is headache inducing!!
    Ron
  1. KZL K300 series LCD Touchscreen USB problem.
    By dmaudio4life in forum LCD/Display
    Last Post: 07-27-2006, 07:47 AM
  2. Please help - usb fm tuner - help me out !!
    By 12345car in forum General MP3Car Discussion
    Last Post: 05-19-2006, 09:23 PM
  3. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  4. Replies: 2
    Last Post: 04-10-2005, 12:18 AM
  5. Fm tuner
    By scandluz22 in forum Newbie
    Last Post: 02-23-2005, 04:48 PM
