Results 1 to 10 of 14
Thread: Config Help?!?!
    Nov 2007
    Config Help?!?!
    Ok, i usually can figure programs out, but RR has me stumped.
    I a sorta trying out RR before i build my carputer. I am having trouble setting it up. I keep getting the message"C:\Program Files\Road Runner\SKINS\Alpine does not contain a valid skin! Check you settings and try again." The issue is i am not using that folder for my skin. I am using "C:\Program Files\Road Runner\skins\DigitalGraphite0.8\" Can someone help me please?
    EDIT: i have been searching for about an hour and have tried multiple skins
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Using my config util should help alot with your probs. Just see the Updated Config thread to dl it. Run it and you should be good from there..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Nov 2007
    the new config isn't working either, i've already tried it.
    any other ideas?
    Nov 2007
    ok, I got it to work once by reinstalling, but now it is not working again and reinstalling wont fix it.
    HELP Please
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    Sounds like you have your skin path incorrect..............
    Leonardo Da Vinci
    Nov 2007
    I have manually edited the skin path's location and i still get the "C:\Program Files\Road Runner\SKINS\Alpine does not contain a valid skin! Check you settings and try again." message
    May 2007
    As I said, seems as if rr is pointing to the wrong location.
    As to why, you'll have to dig it out.
    If your skin choice is digital graphite and RR is trying to go to alpine, you'll have to find out why.
    I assume when you say "manually edited" you mean you've changed the path in rr.ini correct? Did you try it in the rr config utility also?
    If it won't edit to the proper skn either way, you've got some weird issues................
    Maybe a reinstall would be in order.
    Leonardo Da Vinci
    Nov 2007
    It took me a few hours, but i figured it out.
    In VISTA you have to RUN AS ADMINISTRATOR and RUN IN XP SP2 COMPATIBILITY MODE, for future reference.
    Thanks for all your help
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Let also add that when posting about probs, it is very helpful to the helper if the poster states some basic setup stats. If you would have posted that you were taking the running of RR under vista, you might have gotten a quicker fix mention to your prob..
    Just some FYI for future prob posts...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Nov 2007
    i appologize for the lack of information, i have been testing vista for so long that it didn't occur to me to mention it. I also have found that vista is not nearly as incompatible as it was originally believed.
  1. RR Config Updated - Blue ZX3
    By Blue ZX3 in forum Road Runner
    Last Post: 06-09-2011, 04:17 PM
  2. Don't show config window on startup
    By nbinder in forum Map Monkey
    Last Post: 05-24-2006, 02:31 PM
  3. RR install and config PDF
    By accentsound in forum Road Runner
    Last Post: 08-21-2005, 07:27 PM
  4. Questions about RR config
    By Enforcer in forum Road Runner
    Last Post: 07-21-2005, 11:48 AM
  5. Store keypress config? and remote config troubles.
    By lilmansplace in forum Media Engine
    Last Post: 04-08-2005, 05:07 PM
