Results 1 to 5 of 5
Thread: Gps Stats Help
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Gps Stats Help
    Could anyone help me with this impossible question? First of all, sorry my bad english...
    QUESTION 1
    I use a Sirf-III usb GPS, but I always need to do this steps to make it work under destinator:
    1-start the Sirf-demo,
    2-open the port
    3-select syncronize protocol and baud
    there is another solution? please make it simple!
    QUESTION 2
    I cant find how to make the GPS gauges work. yes, I try a port spliter, but even when I use only the gauges it donīt work (I am sure that destinator is off when I try it). I see under RR settings a place to select the GPS port, but I canīt find a place to set the baud rate. How can I configure that?
    Thanks in advance...
    Engineering: Where the rubber meets the road!
    RR Skin RED 2.0 http://www.mp3car.com/vbulletin/rr-s...red-2-0-a.html
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If you use GPS in SIRF mode RR will NOT be able to read it -- in which case you should leave the gpsport setting in RR unused/zeroed... Doesn't mean you can't use the GPS in sirf mode -- just means that any function in RR that uses GPS won't work unless you set it to NMEA mode -- if you do that, the baud settings are 4800 8,N,1 -- standard for NMEA GPS readings.
    Ride Runner RR's Myspace
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    Thanks Guino... I will try it today.
    marteline's Avatar
    Sep 2007
    Brazil, Sao Paulo
    GPS configure
    Now the gauges works, but I still have to configure the GPS settings under sirfdemo every time that I start the computer... I think that now this thread just fit under GPS thread... but...
    there is any way to save the settings on the GPS to work after the start without use the sirfdemo everytime?
    Thanks in advance, once again...
    guino's Avatar
    Nov 2004
    Toronto, Canada
    There should be a command in the GPS itself to do that. I remember my deluo had something like that. Otherwise you may look at what sirfdemo sends, and make a little script to send that to the GPS before loading RR.
  1. How to setup iGuidance GPS for RoadRunner
    By MatrixPC in forum RR FAQ
    Last Post: 05-22-2009, 09:29 AM
  2. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  3. Replies: 3
    Last Post: 08-10-2007, 05:03 PM
  4. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
