Results 1 to 10 of 19
Thread: 800x480 RR resolution -- can it work ?
    Dublin
    Im sorry for asking a load of questions here as i seem to be more of a hinderance than a help to the community at the moment, but once again i have a problem and you guys are the only ones that can help.
    I have RR installed in the car PC , all works great (after much help from a few brilliant people here) and decided to get the screen built into the dash.
    I have limited space and so had to go for a lilliput 7'' touchscreen.
    I discovered that the max resolution on the screen was 800x480 AFTER i bought it.
    Now , the screen works when i set it to this , but Roadrunner still has an 800x600 resolution on it and i can only see part of it.
    My question is , can i set the resolution to 800x400 for RR , or is there a custom skin for the 800x400 screens, and failing that, is it possible to make my own skin that will fit a screen with that limited resolution ??
    Ohh yeah i have a Intel(R) 82852/82855 GM/GME Graphics controller.
    Thanks again in advance for any input.
    Nov 2005
    Pittsburgh
    I use a program called powerstrip to set my resolution to 800x480. Not sure if it will work on an intel graphics controller. Give it a search.
    Colossians 1:16 - Everything
    Dublin
    Thanks , ill give that a go now and let you know.
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    in every skin should be an GENERAL.INI file
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=600
    XPosition=0
    YPosition=0
    because your screen shows 800x480 you must change the value from SHOWHEIGHT= to
    480. thats all.
    Dublin
    ok I tried the powerstrip option and it did nothing for me - also tried the changes to the general.ini file and its a bit better but im missing stuff still.
    I changed the screen res to 640x480 so at least its loading ok now , just RR still isnt displaying the full page ... dont think this screen likes RR
    Aug 2005
    germany
    Quote Originally Posted by djtaz View Post
    for rr its not important whats behind him.
    important is that you give the solution you want in the general.ini AND in the rr.ini of your road runner folder.
    with the roadrunner config its possible to change the values from the rr.ini.
    take the roadrunner config from zx3 and look whats inside.
    under GENERAL SETTINGS page2 you find in bottom position .... RoadRunner at this resolution......
    try with the values inside for best result to your screen.
    i have it on DEFAULT and change it in the general.ini
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Which lilli 7" run at 800x480? I though they were all 800x600
    Dublin
    Quote Originally Posted by GF-ler View Post
    I think i have started to figure out that RR isnt the issue myself - i need to get my graphics controller to display in 800x480 mode before i can move forward , and this looks to be a bit of an issue at present.
    Hope i can figure out how to do this some time soon cause its wrecking my head at the moment.Thanks for the input to date guys - if anyone else has any ideas keep them coming.
    Dublin
    Quote Originally Posted by treetop777 View Post
    I have a Lilliput 7" Touch Screen XGA TFT Car PC Monitor ( EBY701 ) and the native screen size on it is 800x480 - its pretty much the only res it runs properly but it fits into my surround perfectly.
    Jul 2005
    I was in this same boat. Although i was able to set both settings to 800x480 in my .ini and it all looks fine now, although my windows behind still is a lil hard to use.
  1. Replies: 19
    Last Post: 04-21-2010, 05:35 AM
  2. USB accesories don't work running RR from shell
    By Snootch in forum Operating System Optimization
    Last Post: 05-10-2006, 04:51 PM
  3. Repeat Doesn't Work for Winamp / RR
    By mousejunior in forum Road Runner
    Last Post: 06-16-2005, 02:51 PM
  4. tv in rr not work
    By manung in forum Road Runner
    Last Post: 05-13-2005, 01:10 PM
  5. Replies: 13
    Last Post: 09-02-2004, 02:57 PM
