Results 1 to 5 of 5
Thread: RR hanging at startup
    Sep 2007
    Winston-Salem, NC
    I finally got my car PC installed today. I copied a few songs over, got RR installed and everything seemed to work just fine. After the initial test phase I copied the rest of my music over (about 3000 songs, wimpy I know) and now RR hangs when I try to start it. Hanging isn't exactly the right word, it actually just slows my machine to a crawl. So slow that it takes the task manager several minutes to come up. Any idea what I am doing wrong?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Do you have all your music loaded in winamp ? did you by any chance configure anything else in the setup ? can you add debugmode=true to RR.INI and post a log so we see where it's "slowing down".. ? Even with 3000 songs it should not be that slow unless something it's trying to start is unavailable and/or malfunctioning. Check the XM/SIRIUS ports for instance.
    Ride Runner RR's Myspace
    Dublin
    I had a problem with extreme slowness when i had a bluetooth adaptor connected in order to get my GPS working with mappoint - the comm port kept changing and RR was trying to load it on the old port since it didnt know it had changed - this led to a seriously slow machine - unplugging the bluetooth sorted it each time.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    some bluetooth adapters work better than others when they're unplugged. A few will literally halt the system for a few seconds while searching for the device (perhaps making it look frozen).
    kuo
    kuo is offline
    Variable Bitrate kuo's Avatar
    Jun 2003
    Greensboro, NC
    i had something similar to this happen to me when i accidentally copied over a shortcut from my music server to my carpc. when i would start rr, winamp would load and take 99% of the cpu i assume trying to locate the shortcut. once i deleted the shortcut everything worked like it should. don't know if this is what's happening to you but worth a look.
    my car: 2003 g35 coupe, 2.5ghz c2d cpu, gigabyte micro atx mb, dsatx
    wife's car: 2004 honda accord coupe 2.4ghz p4 cpu, asus micro atx mb, opus 150
    company car: 2006 chevy avalanche 2.0ghz p4 laptop, cnx p1900
  1. Switching between RR and copilot
    By CombatCQB in forum Road Runner
    Last Post: 01-26-2009, 05:27 PM
  2. GPS and RR problem =p
    By darkomen64 in forum Road Runner
    Last Post: 09-02-2007, 10:51 PM
  3. RR issue at startup
    By tobiasmarx in forum Road Runner
    Last Post: 11-11-2006, 09:37 AM
  4. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 04:48 PM
  5. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 12:22 PM
