Results 1 to 3 of 3
Thread: Sound Issue after Hibernate
    Mar 2004
    I'm not sure if this is a Windows problem or an issue with RR but I thought I would try here..
    I had to do a reinstall on my CarPC. When I load Windows, sounds is fine. I'll load RR and sound will be fine. The WAV volume will be up and the master volume is at the level as defined by RR. I'll go into hibernate and then come back out of it and there will be no sound even though the volume sliders havent changed. The only way I can get sound to come back is by bumping the wav volume a notch and then setting it back to where it was. This happens every time I go in and out of hibernate.
    Any ideas what may be causing this? If this sounds like a Windows problem, let me know so I can post over there..
    Thanks!
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    try a different output plugin in winamp. Also try hibernating with only winamp open to see. This seems like a driver/winamp plugin issue, but do check that mapmastervol=0 in RR.INI
    Ride Runner RR's Myspace
    Mar 2004
    Quote Originally Posted by guino View Post
    Thanks for the suggestion.
    Actually, I tried shutting off the "Fade In After Hibernate" setting (I don't remember the exact name for it) and it fixed the problem..
  1. pyle pltvdin65 sound issue
    By bigsixx in forum Car Audio
    Last Post: 11-13-2006, 10:50 AM
  2. Replies: 5
    Last Post: 07-26-2006, 12:17 AM
  3. FS: USB Sound Blast Live 24 bit & Pioneer 4 Channel 300watt amp
    By clean customs in forum Classified Archive
    Last Post: 05-21-2005, 11:04 AM
  4. Sound Card discussion, 4.1, sound quality, need help
    By jedi7001 in forum General Hardware Discussion
    Last Post: 05-19-2005, 10:47 AM
  5. got sound?
    By masch in forum Newbie
    Last Post: 11-17-2003, 10:01 AM
