Results 1 to 10 of 11
Thread: Please explain gamma settings
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by vladcarpc View Post
    Hi,
    I have a Lilliput 8" Wide Model 889GL-80NP/C/T, using RR and it's built in gamma control.
    At night, the brightness of the screen is still too high.
    It is not secure. People from other cars or pedestrians can notice the screen very easily at night.
    So, what settings are you using in your gamma configuration? Or what else are you configuring or doing to reduce screen brightness at night?
    PS: At day normal or high brightness is important.
    Thank you
    Above is a question from another member that didn't get any response in the monitor forum which i'm also interested in. I'm posting it here in hopes of getting a better response.
    Basically, the monitor (8" lilliput 889GL) is too bright at night even with the normal "default" reduced gamma. Would like to know how gamma works and what settings to change to get it darker.
    I (we) know there's a gamma setting in config; just don't know how to accomplish the above.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    To make it darker you want to make the colorls farther away from zero on the negitive side. default is -50, so try -75 ect..
    what this does is changes the brightness of each color up or down, although many argue that dimming by using gamma doesn't do as good job as a reduced backlight. The reduced backlight is a much better resulting dimmed picture, but w/o the know-how, time, effort...ect the gamma route is just easier to use, it just doesn't give as good results...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Sep 2006
    War-Town, GA.
    Thanks ZX3, another question if i may: which take presedence, the gamma specified in general.ini or the one in your config? Do they interact in any way?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    The skins gamma settings (from the last skin loaded) should take over if they exist, otherwise the config ones are used.
    Ride Runner RR's Myspace
    Sep 2006
    War-Town, GA.
    Thanks. At -80 (the max you can go?) it dimms considerably, much better than before.
    Now i got to keep searching to see if i can find how to make it come out of dimm when the screen is touched (to make changes in playlists and such) then return to dimm after some idle time..
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Could be done with the idle skin command only if the gamma setting were able be be set/changed on-the-fly.
    Unless I'm wrong...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    IDL,30 GAMMA
    wouldnt this work
    Idle 30 seconds then gamma
    New Age Garmin - Skin for RR
    Feb 2007
    Springfield, Mo
    IF the settings in the skin are messing with the settings in the control. What is the best way to fix this? What is the best way to remove the settings in the skin general file?
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by WassonA View Post
    Somebody correct me if i'm wrong but i think if you set these all to 0, the settings in config will take over.
    GammaDayRed=0
    GammaDayGreen=0
    GammaDayBlue=0
    GammaNightRed=0
    GammaNightGreen=0
    GammaNightBlue=0
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    This is my General.ini
    OriginalWidth=800
    OriginalHeight=600
    ShowWidth=800
    ShowHeight=480
    XPosition=0
    YPosition=0
    All the rest for the gamma is in rr.ini
    [Gamma]
    gammamode=2
    gpsgammamodeoffset=0
    gammaday=0:0:0
    gammanight=-50:-50:-50
    gammadaytime=6:00
    gammanighttime=18:00
    autogammamode=0
    autoskinmode=2
  1. Draft RR Help file
    By kpjuk in forum Road Runner
    Last Post: 04-08-2009, 09:00 PM
  2. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 09:56 PM
  3. GoogleEarth GPSR Tracking
    By briefnotion in forum GPS
    Last Post: 09-11-2007, 08:32 PM
  4. [Release] SKINbedder BETA 2.99999
    By 0l33l in forum SkinBedder
    Last Post: 09-23-2005, 04:38 AM
  5. Settings 1 and settings 2?
    By wysocki in forum FrodoPlayer
    Last Post: 11-17-2004, 03:43 PM
