Results 1 to 5 of 5
Thread: How to start RR on 2nd monitor?
    Nov 2007
    Hi all. I'm setting up a laptop for use as a CarPC. Currently I have the built-in LCD screen running at 1400x1050 and the VGA output set to 800x480.
    When I start RR it appears on the built-in LCD screen, but I would prefer it to start on (and basically just 'own') the monitor attached to the VGA output. Is this possible?
    Thanks!
    Jul 2006
    try making that monitor primary in display properties
    Nov 2007
    I was hoping not to have to do that... but I'll give it a shot if nobody has a better idea.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you can specify the POSITION for the skin to appear in general.ini -- if you have the monitor on your right (the position is set in the settings tab of display properties) then you should set XPosition=1401 for instance or something like that.. just try different values beyoud the current monitor's resolution.
    Ride Runner RR's Myspace
    Nov 2007
    Thanks Guino, that's what I needed.
  1. RR hangs on start up
    By stuart_hatch in forum Road Runner
    Last Post: 10-16-2006, 11:14 AM
  2. Replies: 4
    Last Post: 10-01-2006, 01:01 PM
  3. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  4. Replies: 0
    Last Post: 06-11-2006, 06:49 PM
  5. RR hangs on start up
    By fixerofallthing in forum Road Runner
    Last Post: 04-16-2006, 11:05 PM
