Results 1 to 9 of 9
Thread: HD Radio Commands
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    HD Radio Commands
    DO we have somewhere a list of available commands and indicator codes for the HD Radio?
    RDS an STEREO don't semm to work.
    MySQL Error
    Oct 2004
    i think they are in the skin commands text file
    thats where i saw em
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    I made a list for my own reference not too long ago... And here it is..
    INdicators:
    "HDACTIVE" - HD Radio Signal Active (For MitchJS's HD Radio tuner)
    "SURF" - Radio Surf Mode (Same as "SCANMODE")
    "STEREO" - Radio Stereo (Works with DLink, Cinergy & HQCT ONLY)
    "SCAN" - Radio Scan Mode (Indicates whether FREQ+/- will "seek")
    SLider Codes:
    "HDSIGNAL" - HD Radio Tuner Signal Strength (Road Runner Only -- for MitchJS's HD Radio Tuner only)
    "RSIGNAL" - Signal strength of the radio station received
    --- Radio Support Labels ---
    "HDARTISTX" - HD Artist on Sub Channel X
    "HDTITLEX" - HD Title on Sub Channel X
    "HDSUB" - Current HD Sub Channel
    "HDSUBCOUNT" - Number of Sub Channels Available for current Station
    "RDSNAME"/"RDSTEXT" - Those also may provide information about the Current Station for HD Radio
    "FMAM" - Inficates if the current frequency is FM (True) or AM (False)
    "FREQUENCE" - Radio FrequencY (Yeah, it's misspelled to support older MediaCar skins)
    "STATION" - Current Station Name (Radio)
    "PRESET" - Current Preset Number (Radio)
    "RDSNAME" - RDS Name of Station (if any)
    "RDSTEXT" - RDS Text from Station (if any)
    "RDSSIGNAL" - RDS Signal Level (SiLabs Radio Card Only)
    "PTY" - RDS Program Type currently received (PTY)
    --------------------Commands:
    "HDSUB" - This allows you to select the HD Radio SubChannel for the current station.
    Example: "HDSUB;1" (First Channel -- default)
    "HDSUB;2" (Second Channel).. and so on from 1 to 6
    "RADIO" - Loads the Radio Player Screen (radio_player.skin) -- Same as "LOAD;RADIO_PLAYER.SKIN;RADIO"
    "PLAY" - Cycles through a Play/Pause state of current song. (RR Only) When Radio is ON, acts as "PRESETMODE"
    "STOP" - Stops the playback of current song. (RR Only) When Radio is ON, acts as "SCAN"
    "FREQ+" - Increases Current Radio Frequency
    "FREQ-" - Decreases Current Radio Frequency
    "SCAN" - Turns On/Off Scan mode in the Radio Screen. In scan mode, freq+/- act as a seek function.
    "SURF" - Same as "SCANMODE" (below)
    "TUNE" - Shows NUMPAD to enter a frequency/channel to tune into on Radio/XM/SIRIUS
    "PRESET" - Shows NUMPAD to enter a preset number to jump to (Radio Only)
    "RADIOMUTE" - Mutes/Unmutes the radio
    "FUNCTION" - Shows up the RADIO_MENU_FUNCTION.SKIN menu.
    IN RADIO_MENU_FUNCTION.SKIN:
    "ADD" - This shows the OSK and allows you to enter a name to save the preset for current frequency.
    "MOVE" - This allows you to use UP/DOWN to move a radio preset into a position of liking.
    "MODIFY" - This shows the OSK and allows you to edit the name of the selected preset.
    "DELETE" - This deletes the selected preset.
    "SCAN" - This searches any stations and adds them to the playlist as presets
    "SCANMODE" - Toggles scan mode. This works with MP3, TV and Radio as well
    "ADDPRESET" - This shows the OSK and allows you to enter a name to save the preset for current frequency
    "DELPRESET" - This deletes the selected preset
    "EDITPRESET" - This shows the OSK and allows you to edit the name of the selected preset
    "PRESETUP" - Switches to Next Preset
    "PRESETDOWN" - Switches to Previous Preset
    "SEEKUP" - Seeks (finds) next Radio Station
    "SEEKDOWN" - Seeks (finds) previous Radio Station
    "TUNEUP" - Changes Frequency UP by 1 MHz
    "TUNEDOWN" - Changes Frequency DOWN by 1 MHz
    "FINEUP" - Changes Frequency UP by 0.1|0.2 MHz (0.1 is used when Allowing all frequencies)
    "FINEDOWN" - Changes Frequency DOWN by 0.1|0.2 MHz (0.1 is used when Allowing all frequencies)
    "MONO" - Toggles Mono/Stereo mode of Cinergy 600 and Radiator supported FM tuners
    "PRESETMODE" - Toggles Preset Mode ON/OFF. When the RADIO is ON, "NEXT"/"PREV" work as Seek UP/DOWN.
    In Preset Mode, "NEXT"/"PREV" switch presets UP/DOWN instead of seeking the radio.
    "SEARCHPRESETS" - Enter the search preset mode (Radio). This clears and adds found presets onto the preset list.
    "LOCAL" - Toggles the Local Mode for the Radio Presets. While in local mode, any changes presets
    that are searched, added, edited or deleted do not affect the main list of presets.
    "AF" - Toggles the RDS Alternative Frequency function.
    "TA" - Toggles the RDS Traffic Announcement function.
    "PTY" - Toggles the RDS research by program type (PTY).
    "FMPRESET" - Save/Load a Preset for the current Radio frequency. You can use this to make preset buttons for
    the radio feature. Presing and holding the button will save the current frequency to the name
    specified to this preset. Pressing the button normally will load the named preset frequency.
    Example: "FMPRESET;PRESET1" (load/save current frequency from/to preset name PRESET1)
    "RADIOBAND" - Toggles AM/FM Band
    New Age Garmin - Skin for RR
    Aug 2006
    West Allis, WI
    Taken from the Skin Commands txt
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    Good thread to start, working on my HD menu skin also.
    Is there a way to save the presets on the HD menu?
    I don't use the preset buttons, I use a preset list (you can just click on the preset there)
    BUT..
    It seems any time I shutdown RR or even use "LOCAL" command all my presets are wiped out.
    I believe the presets are supposed to be written to radio.ini in RR root folder but this file also remains blank.
    Are you HD skinners experiencing similar behavior?
    Low Bitrate lor109's Avatar
    Mar 2004
    Quote Originally Posted by blk02si View Post
    BUT..
    I know it's been a year since you posted this but I've been having this problem ever since upgrading RR. Did you ever figure it out?
    Maximum Bitrate fixerofallthing's Avatar
    May 2005
    Lawrenceville GA
    Quote Originally Posted by lor109 View Post
    Look at Carwings skin. It has this feature built in.
    The Car 2005 Scion xB
    The Truck 2004 GMC Canyon
    Aug 2007
    Roma
    Hi,
    Ihave a Silabs usb radio, but the RadioMute or Play or Stop don't work .... I want have a button that stop the listen radio... it's possible ?
    thanks.
    MySQL Error
    Oct 2004
    RIKO, make sure your using the JULY 2009 release of RR
    also, with silabs, the usbradio.dll is in control, if it supports mute... it will mute
    and there is quite a buch of versions of this .dll...
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. HD Radio Cables READY!
    By mitchjs in forum User Innovations
    Last Post: 09-27-2011, 03:57 PM
  2. Got HD Radio, adding Sirius and XM.. what are my options?
    By Sonicxtacy02 in forum General Hardware Discussion
    Last Post: 12-14-2007, 08:39 AM
  3. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  4. HD Radio Question...
    By Shidoken in forum Car Audio
    Last Post: 11-29-2006, 10:04 AM
  5. HD Radio for the PC?
    By dodgetimes2 in forum Car Audio
    Last Post: 08-03-2005, 11:35 AM
