Results 1 to 10 of 12
Thread: Which front end is this??
    Variable Bitrate TeamRSX's Avatar
    Nov 2007
    Ottawa, Ontario
    I am currently looking for a front end software for my newly built carpc for my Acura RSX-S.
    I was browsing this site and game across one i really liked from the forum 'Show off your project', but am not sure which front-end + skin they are using.
    Can anyone tell from the pic below the front-end + skin. I realize it could be a custom made front end, but let me know what you think.
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by TeamRSX View Post
    its ULTIMATE 04 from CDR. its a flash based frontend running perfectly.
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by GF-ler View Post
    Do you know where to download this software? Is it freeware?
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    It is road runner, with the freedom ultimate skin. Search the skins section and download road runner.
    New Age Garmin - Skin for RR
    Low Bitrate Maddominican's Avatar
    Jan 2007
    Hispaniola
    Ok... First, D/L Road Runner and install, and then, D/L Freedom Ultimate and install. Presto!
    Nov 2007
    Ottawa, Ontario
    Quote Originally Posted by Maddominican View Post
    Thanks for your help. I have already downloaded RR and installed Freedom Ultimate, but am having problems with images for the main menu being too large. I have attached a pic. I have circled the images on the main menu as they are too large and also noticed no image in the top right of the player also circled in red.
    Let me know if anyone can help. I realize this is a beta version, but think the images should align. If you need me to supply config files let me know.
    Blair
    Constant Bitrate Tensai's Avatar
    Jun 2006
    Texas
    Check your DPI settings. (Right click on desktop->Properties->Settings Tab->Advanced) 96 DPI is normal, but it looks like you running at a pretty high resolution so the DPI setting may have been scaled as well. That could through things like icon size off a bit.
    Is it that it's fun? Or that it lets you forget yourself?
    Nov 2007
    Ottawa, Ontario
    I was using the wrong images. I was using the images in the settings folder which are 60x60pixels. The ones i should be using are in the icons folder and are 50x35pixels. I have tried it with the smaller images and works fine.
    Does anyone have a utility to resize images? Would imageready work?
    Blair
    Nov 2007
    Ottawa, Ontario
    Ok, now i am having a problem with night mode.
    I now have the Freedom Ultimate skin and evey time i load RR with FU Skin it goes into night mode automatically. When i push the button which switches from day to night only the the skin color changes, but remains in night mode all the time.
    I have the day time and night time set properly, but no other options for day/night mode that i am aware of. This just started to happen, so wondering if there is an option i can play around with
    Blair
    Aug 2005
    germany
    I now have the Freedom Ultimate skin and evey time i load RR with FU Skin it goes into night mode automatically. When i push the button which switches from day to night nothing happens.
    Blair
    if you go with your mouse cursor on the clock (left/top) and click on it, its jumps to a lot of menus of selections.
    in this menu is also written which time the day/night mode should be activated.
  1. what front end do you use?
    By emdzey01 in forum Software & Software Development
    Last Post: 02-24-2006, 08:07 AM
  2. 100% Plugin based Front End
    By custardbomb in forum Software & Software Development
    Last Post: 10-07-2005, 01:17 AM
  3. Searching for the right Front End
    By ninjatill in forum Newbie
    Last Post: 09-10-2005, 03:47 PM
  4. which front end for no touch screen?
    By turbochris in forum Newbie
    Last Post: 08-30-2005, 10:59 AM
