Results 21 to 30 of 33
Thread: Problem with Autoskin
  1. #21
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    NO...Just you...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  2. #22
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    "what plugin??"
    Just 4 that you will be disabled to using it....LOL
    Does this mean my mp3Car ratings will go down the pan ?
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
  3. #23
    Nov 2004
    Leicestershire UK
    NO...Just you...
    Rubbish
    I understand there is a terrific plugin in Windows called Notepad I think I'm going to start using it
  4. #24
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Enforcer *2
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  5. #25
    Nov 2004
    Leicestershire UK
  6. #26
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Quote Originally Posted by Enforcer View Post
    OK I have looked at the code.
    The GPS gamma is mainly one module so it wasn't hard to find
    Anyway looking at it, it looks like changing the BIAS according to whether DLS is set on or not was not added. I have found some code which is similar and takes care of that.
    I will have a look and see if I can add it to the module over the next week or so.
    Then pass the info to Guino to see if he wants to add it.
    Being you found the module, and all already....could you do me a small favor, and make 2 commands that will activate based on the day and night switch? This should take less than a couple minutes, even less if you are using notepad One for when it "senses" day, and one for night.
    Something like DAYSWITCH & NIGHTSWITCH. This command would be fired when the day or night took place based on what is in the exectbl.
    So, something like this would be possible:
    "DAYSWITCH","RUNQ;SwitchDayColorSKin.exe"
    My Fiero Build Thread
  7. #27
    Nov 2004
    Leicestershire UK
    Possible Solution ?
    I've just been playing around with RRConfig Skin/Gamma Settings while it's sunset here in the UK..............and I have found the following, with these settings:-
    Use Built in Gamma with GPS
    Auto Gamma change Disabled
    Auto Skin change
    With (minus)-60 in the "Gamma offset in minutes" window, it appears to auto skin change at the correct time for UK Standard Time sunset. Hope I'm right
    Can anyone else using autoskin change try this and confirm please ?
  8. #28
  9. #29
    Nov 2004
    Leicestershire UK
    Just remember to change it when the clocks go back
    E
    My skin didn't change at sunrise this morning, as expected So it doesn't look like gamma offset works in the way I thought it did (:massive embarasment: )
    Could you please still have a tinker with the code, as you were going to do ?
  10. #30
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Quote Originally Posted by wizz View Post
    E
    My skin didn't change at sunset this morning, as expected So it doesn't look like gamma offset works in the way I thought it did (:massive embarasment: )
    What part of the world do you live in that the sun sets in the morning? This could be your problem
    This problem has come up over and over again, and I am about to get the RR source myself and see if I can figure it out once and for all. Either that or an extension plugin. This is such a very simple thing to do, and just have been overlooked for so long, and gets swept under the carpet within a week of the time change.
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
