Page 1 of 4 1234 LastLast
Results 1 to 10 of 33
Thread: Problem with Autoskin
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Since switching back to UK Standard Time for the winter months my autoskin switchover is exactly one hour later than sunrise/sunset. Is there a way to compensate for this ?
    I see there is an offset in the gamma settings but I understand from the "readme.txt" this is to allow for a timed gradual change and not, as hoped, an immediate offset switch.
    Can anyone help ??
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Run the new RR.config and change your times for what you want.
    Possible for gapa to switch gamma profiles automatically?
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by MGD View Post
    You miss-understand, I am not, and do not wish, to use set times.....I am using GPS autoswitch.
    This allows for an auto skin change in sync with the changing sunrise/sunset times. The problem arises when UK Summer Time changes to UK Standard Time and our clocks are adjusted forward by an hour. I need some way to compensate for this.
    For Example; Sunset today here in the UK was 3:56PM. My skin changed at 4:56PM. If I had still been on UK Summer Time....the skin change would have occured at the correct time.
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Does you GPS receiver displays the right time?
    GPS should auto adjust to summer and winter time.
    Nov 2004
    Leicestershire UK
    No idea.....I use MapMonkey for SatNav.....where do I find the GPS time ??
    PS: Come to think of it......I seem to remember I had this trouble last winter
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Yes, the same prob exits in the us while in standard time, it took me awhile to figure it out b/c for a while it was working (daylight savings time period) and when it switched I started to notice that my gamma started to be way off...
    The code that is in RR does have the compensator, but if I recall correctly, its hard coded as one or the other, which should be a setting to allow for correct usage. And from my research on the feature, I couldn't find a easy way to check if win is using std or dst.
    Needs to be fixed though...
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Nov 2004
    Leicestershire UK
    That's going to be hard. You are probably aware that the original code was written by Skippy76, who I think no longer frequents the forums. When I last approached him ( probably this time last year ! ) he said it was such a long time ago he doubts he could find the code again.
    BlueZX3 What effect would the Gamma offset have on the skin switch if this was designed to phase the gamma over the offset time ?? You couldn't have a skin switch over a 60min offset time could you. LOL
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    I am not a programmer but it should not be to hard to do.
    We have he weather channel's sunset and sunrise times.From there it should not be to hard with the EVAL function in RR.
    If windowsTime=SunsetTime Then
    Switch skin else
    end if
    Nov 2004
    Leicestershire UK
    Switch skin else
    end if
    I've noticed that my weather skin functions differently now to how it used to do. I do not have a permanent internet connection in my car, but the page retains the weather data for the five days until it is updated. Before, when the weather skin was selected without an internet connection the data was lost. This could be a plus factor in collecting sunrise/sunset data, as you suggest, because it must now be stored somewhere on the HDD.
    Could anyone crack this thing ? ...............looks like it's not just a UK problem as I first thought, but a US one too.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    All the code is already in rr, it just needs to be tweeked a little...Y re-invent the wheel?
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. reconnected puter and now audio problem..
    By NYCdesignkid in forum Car Audio
    Last Post: 05-31-2006, 12:09 AM
  3. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
