Results 1 to 10 of 11
Thread: RR and mpeg-2 files
    May 2005
    Toronto, ON
    RR and mpeg-2 files
    I can't seem to figure this out. RR is not able to play mpeg-2 files. I'm using ffdshow. These files can be played fine using mplayerc and mp11. However, when I try to play these files in RR, it just skips over the file. Any ideas?
    May 2005
    Toronto, ON
    That's what I figured at first. That's why I tried using the internal mplayerc in roadrunner. It plays the file fine. So I'm not sure why going through RR, it just skips over the file. The title of the file shows up for a brief second, an then it jumps to the next file in the playlist.
    May 2005
    Toronto, ON
    I just tried it on another computer (with different codecs installed), and I got the exact same results. Which codec do you need for Mpeg-2, m2v playback?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    VOBFilters should do it.
    Ride Runner RR's Myspace
    May 2005
    Toronto, ON
    Where do I find VOBfilters? I've tried installing what I found, but they do not do anything. It just seems like the internal video player is not playing the mpeg-2 files correctly. If I use mplayer classic, it's fine. I've tried installing codecs, vobfilters, everything. It just seems like there's a setting that's not right.
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
    May 2005
    Toronto, ON
    That's the one I tried. Still no luck...
    I'm going to try installing PowerDVD to see if that helps.
    moahdib's Avatar
    Jul 2000
    I have smae problem with MPEG=2 video files and buitl in RR. Just doesn't playthem. Specifically m2v videos. I have just about tried everything and gave up -_-
    04 Acura TL w/ core2duo 2ghz laptop w/ 1gb RAM on a docking station.
    Fast car, fast PC. ;)
    http://www.arcdesigns.net/carpc/
    My TL CarPC ver2
    FSR Flash Skin w/ moving weather maps
    May 2005
    Toronto, ON
    FYI...for anyone who might have the same issue.
    I figured it out. It was a codec issue. The VOB Filters listed above, work. However, the video was out of sync. The video would play at a very fast speed. Those are a much older version of Ligos MPEG decoder and parser.
    I ended up downloading an older version of K-Lite Codec Pack, version 3.20. This version has the Ligos MPEG decoder (You have to manually select it though). None of the other codecs were working for me.
  1. Proper way to setup my CarPC using RR
    By black_mamba in forum Road Runner
    Last Post: 11-17-2007, 07:02 PM
  2. MPEG 4 and titles...
    By kgasso in forum Road Runner
    Last Post: 01-20-2007, 11:55 AM
  3. Won't play certain MPEG videos
    By sssssss27 in forum Road Runner
    Last Post: 02-24-2006, 01:22 PM
