Results 1 to 7 of 7
Thread: popup skins & ilists
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    has anyone noticed that pop up skins don't work nicely infront of ilists?
    i mean popups like NUMPAD etc..keep up flashing (they work correctly though)
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Nope never seen it. Thanks for the observation.
    Also for some reason if I am using an OSK smaller than the actual skin, it doesnt show up on top of the previous screen. The previous dissappears and then displays the OSK. Only when called from the OSK command though.
    WIERD
    New Age Garmin - Skin for RR
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I would imagine that because the way that the ilists are drawn is why anything on top of an ilist is going to do this until someone(guino?) fixes it, by idk...telling the list control not to paint to the screen if something is on top of it???
    Just a tad too advanced for me yet....
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If the popup is transparent/semi-transparent, that may happen because windows needs to re-calculate the pixels from what's in the background which changes 30 times per seconds. It should not happen with solid popups however.
    Ride Runner RR's Myspace
    Aug 2006
    West Allis, WI
    That's not the case though. At least with the problem I am having. I used a non-transparent OSK that is smaller than the normal like 600x300 and the previous screen will dissappear and then the OSK comes up. Still works but it is like the OSK is being called with a load command instead of the menu command.
    Any thoughts or ideas for this...
    Apr 2006
    Greece
    Quote Originally Posted by guino View Post
    yeap..
    removed "v,90" and everything is OK..
    thanks
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by ThunderStick View Post
    Either the OSK is transparent and you don't know it OR it has some sort of control in it causing it to refresh (i.e. Flash/Another iList) ? I have just tested this, but if you want to try it, just get the BMV2 skin and make the playlist into an iList and press the GPS Menu button...
  1. CentraFuse Skins for Download
    By TheFireBall in forum CF Skins
    Last Post: 08-19-2008, 02:38 PM
  2. iLists makes my RR freeze
    By tundra2000 in forum Road Runner
    Last Post: 12-30-2007, 05:43 AM
  3. Is the skins forum getting to cluttered?
    By Enforcer in forum Road Runner
    Last Post: 10-18-2007, 08:59 AM
  4. Skins, skins, skins and... skins (and NOTHING MORE)
    By netsuo in forum NeoCar Media Center
    Last Post: 12-21-2005, 08:12 AM
