Results 1 to 7 of 7
Thread: Howto specify MPH for GPSspeed.swf?
    Jul 2006
    I noticed that the "GPS stats" screen seems to show the speed in KPH instead of MPH, but the speed in iG4 is correct in MPH. After digging around in GPS_Status.skin and I still cannot figure out how to set the MPH for GPSspeed.swf.
    Is this even possible?
    FLAC Nomader's Avatar
    Apr 2006
    Greece
    what skin r u using?
    well it really deppends on how the "GPSspeed.swf." you are reffering to is designed..
    it is either designed to read km or miles. you can not change that unless you have the source
    Variable Bitrate GF-ler's Avatar
    Aug 2005
    germany
    Quote Originally Posted by Nomader View Post
    i think, no one will fix it in his source.
    the only different is the scale.
    i dont think your car will drive 300 mi/h, in km/h we do it.
    some posts behind this, its written what to do if you want to see miles or km/h... why you guys didn,t use the search function.
    by the way, its set in rr.ini GPS
    ISUNITS = true ....... =km/h and meter
    ISUNITS = false ..... = miles and feet
    Apr 2006
    Greece
    Quote Originally Posted by GF-ler View Post
    where is that search function?
    well to explain more of how "most" swf speedos work
    they have each frame as 1 speed unit, then the movie will go to the frame that equals the speed of which rr sends to the swf.. so if RR sends "40" the speedo will show "40" it does not matter if it is km/hr or mi/hr.
    the problem is it sure looks funny to have a mi/h speedo showin 220mi/hr!!! and stating "km/hr" on top..
    so you need the source to have a nice looking speedo showing mi/hr as i told you in my previous post
    Jul 2006
    Okay after playing around with the "ISUNITS" setting I found out it's reversed on my carpc.
    ISUNITS=true will set unit to MPH, the DFX2.0 skin displays MPH everywhere, and GPSspeed is actually showing the right speed now.
    ISUNITS=false will set unit to KMH, reversed to whatever above.
    The only reason I can come up with is because my USB GPS receiver is bought oversea where they are using KMH, is that even possible?
    Aug 2005
    germany
    Quote Originally Posted by msun View Post
    i think no GPS factory would fix if its KM or in Miles.
    I think its to fix in the ini of IGuidance.
    the reason for it is the same as its in the software. every small change must change in all languages. who will pay for it ?
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Just a note, there is now a MPH and KPH button on the GPS Stats screen to switch to whatever you want "on the fly" so to speak Just like the button on the dash with a digital readout to switch back and forth
    My Fiero Build Thread
  1. KPH to MPH in RR GPS
    By pnevai in forum Road Runner
    Last Post: 03-16-2009, 04:46 PM
  2. Should the MPH work in NAV yet?
    By racerx9146 in forum Centrafuse
    Last Post: 05-03-2007, 05:19 PM
  3. KMH to MPH!!!!
    By Griff1 in forum Map Monkey
    Last Post: 05-26-2006, 05:57 AM
  4. HOWTO for Lilliput Touch Screen for Linux
    By turbodog00 in forum Newbie
    Last Post: 09-26-2004, 02:07 PM
  5. HOWTO: Co-axial Splice
    By lgbr in forum Car Audio
    Last Post: 05-16-2004, 01:56 AM
