Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Pink Ilist,,, BAD
  1. #11
    Nov 2004
    St Louis
    Actually, I admit I dont completely understand the IL,,,, command and I was missing one of the .bmp files that were required for the skin.
    Glad it worked for you.
  2. #12
    High Voltage blk02si's Avatar
    Jul 2005
    Motorcity
    Blog Entries
    1
    One work around is to use a solid pink .bmp that is sized to 800x480 or 800x600 depending on your resolution.
    Nice screencap of shock series skin I've been seeing more and more of this skin in production use lately
  3. #13
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    any info on my issue? anyone else seen it?
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
  4. #14
    May 2008
    The color is actually called magenta and has historically been used for video overlays. Some video players and video capture programs will set this. Roadrunner may be using this trick to produce transparencies.
    The only fix I've been able to find is to decrease your video acceleration settings. Not saying that there aren't others.
    Some history and the "fix" here.
  5. #15
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Quote Originally Posted by Quattro View Post
    It looks like the DirectX is either running out of resources and/or discarding the bitmap surface (thus rolling the list re-builds the surface might fix it)... but that is odd (unless you just resumed from hibernation/standby)... check how much memory you've alocated for the video card, update DirectX if possible or try a different resolution (even if just to test).
    Ride Runner RR's Myspace
  6. #16
    Jul 2005
    Motorcity
    Blog Entries
    1
    Thats right, Quattro is running his OS from flash (I believe), and only 512 Ram, so running out of resources sounds like a legit reason.
  7. #17
    Dec 2003
    New York
    Quote Originally Posted by guino View Post
    I don't remember which version of DirectX I have, but I'll check to see if there's a new version. I have a built in video card with 64mb, I was thinking of trying a different set of nVidia drivers.
    btw, I do use standby.
    Installed
  8. #18
    Dec 2003
    New York
    Quote Originally Posted by blk02si View Post
    no I'm running off the hard drive, but I do have 512 Ram.
    Installed
  1. Tview t700ts - Bad drivers or bad touchscreen?
    By HyperZulu in forum LCD/Display
    Last Post: 02-21-2007, 02:00 PM
  2. Panasonic UJ-845-B bad or did i simply order the wrong stuff?
    By kireol in forum General Hardware Discussion
    Last Post: 12-05-2006, 08:07 PM
  3. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 07:08 AM
  4. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 11:49 AM
  5. how bad is composite video
    By kderedwolf in forum LCD/Display
    Last Post: 09-23-2003, 01:04 AM
