Results 1 to 10 of 18
Thread: Pink Ilist,,, BAD
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Pink Ilist,,, BAD
    I have had no trouble with the ilists up until now.
    I was using some screen capture programs to take a video of RR in action.
    Since then I have had pink ilists when they should be transparent.
    Any ideas..
    Here is the code I am using
    Ilist code
    IL,PL,RGBFF00FF,RGBFF00FF,,2,20,50
    Play List Code
    S,123,325,660,144,255,255,255,0,0,0,255,255,255,36 ,36,255,255,255,255,TRUE,#PLAYLISTFontsize#,#FONT1 #
    Thanks in advance
    New Age Garmin - Skin for RR
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Yikes! Looks like you are gonna have to re-do your skin to match the iLists!
    Hahahah sorry. I have not seen that happen before, are you running XP or Vista?
    My Fiero Build Thread
    Aug 2006
    West Allis, WI
    XP, the thing is the ilists were working great. I dont know if it is just my computer or if this is an RR thing. I tried switching it to use the transparency.bmp instead by then I get a blank list. I read the thread on that problem but did not have an answer for me. I have all the color settings as they were and filled in. But for some reason I get pink. Im guessing this is the color used for transparency and that transparency for some reason is not working.
    Aug 2006
    West Allis, WI
    Ok Problem solved, it was one of the screen capture programs I was using. I did a system restore and VOILA! problem solved.
    Thanks john for tapping in...
    Variable Bitrate Spawn12336's Avatar
    Nov 2005
    Toronto, ON
    I have an issue with this now as well. But only if I am using 16-bit mode in the display properties. I'm trying to solve some performance issues when using igo8 and 16-bit helps alot, but now I have the pink lists... damnit. any ideas?
    "the universe has a way of balancing itself"
    http://i15.photobucket.com/albums/a3.../Webbanner.jpg
    May 2006
    Chicago
    Quote Originally Posted by Spawn12336 View Post
    Run far away from igo8?
    I am the stig's cousin.
    Nov 2004
    St Louis
    I got rid of mine by copying all the .bmp files from DFX4 into my skin and reset the IL,,,, line to match John's.
    Nov 2005
    Toronto, ON
    Quote Originally Posted by lewcamino View Post
    Being one of the guys who has done the majority of the work making iGO8 usable in a carpc, I'll stick with it... but thanks for your input (do a search for spawngo8, and no, i will not distribute). I've been using it since January in my truck and had no complaints.
    Thanks GizmoQ, I'll try that.
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    I have a problem with iList as well, its similar to your guys problem but different. I attached a couple of pictures of it. The list gets distorted once in a while, but if I move the distorted part out of viewable area and bring it back it fixes it. Its very random when it happens. Lets say I have the playlist on shuffle and I press forward, the list will get distorted, if i press back and forward again it will be fine.
    anyone else seen this?
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Nov 2005
    Toronto, ON
    GizmoQ, that worked, so apparently text mod ilists cannot show transparent in 16-bit display mode. A little editing in photoshop to match the skin and all is well.
  1. Tview t700ts - Bad drivers or bad touchscreen?
    By HyperZulu in forum LCD/Display
    Last Post: 02-21-2007, 03:00 PM
  2. Panasonic UJ-845-B bad or did i simply order the wrong stuff?
    By kireol in forum General Hardware Discussion
    Last Post: 12-05-2006, 09:07 PM
  3. Auto power off
    By accord in forum General Hardware Discussion
    Last Post: 08-15-2004, 08:08 AM
  4. Bad Serial Ports on EPIA M9000
    By wi77iam in forum General Hardware Discussion
    Last Post: 05-06-2004, 12:49 PM
  5. how bad is composite video
    By kderedwolf in forum LCD/Display
    Last Post: 09-23-2003, 02:04 AM
