Page 1 of 3 123 LastLast
Results 1 to 10 of 28
Thread: Enable voice control wherever a textbox/OSK exists? HOW??
    Nov 2005
    Does anyone know how I can enable Voice Control whenever the OSK/text Cursor appears?
    I dont want to control RR with it, only enter text and have it auto trigger whever there is an opportunity to type.
    EG:
    Enter address in Satnav
    Enter track title in music search
    Fill in Album/Artist/Genre in CdRip plugin
    Enter a phone number in Phoco/Freefone/RRmobile
    Is there an elegant/correct way to have this occur? something like trapping every call to OSK, or detecting wherever there is a text cursor/input field on the screen?
    Any other ideas?
    Ice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Only by a means of a plugin you'd be able to check if RR is in either NUMOSK.SKIN or OSK.SKIN and have the voice control activated... I'd suppose you could also have a timer in NUMOSK.SKIN and OSK.SKIN which executes a command to activate the voice, and then have another command in the ESC/ENTER buttons of the OSK so it disables the voice control.
    Ride Runner RR's Myspace
    Nov 2005
    Is there any way to detect if the pointer has become a text cursor ?
    and doing it that way?
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    try this. simple very simple script.
    Code:
    #Include <Misc.au3>
    AutoItSetOption("WinTitleMatchMode", 3)
    $test = "test"
    If WinExists($test) Then Exit
    AutoItWinSetTitle($test)
    $rr=ObjCreate("RoadRunner.sdk")
    if not IsObj($rr) then Exit
    $oMyError = ObjEvent("AutoIt.Error","MyErrFunc")
    HotKeySet("!{esc}", "_exit") ;for testing only, exit ALT+ESC disable when no need for it.
    While 1
    	If  $oMyError.windescription then
    		if Not WinExists("RoadRunner") then ExitLoop ;exit if RR is not Running.
    	EndIf
        if MouseGetCursor() = 5 And _IsPressed("01") then
          MsgBox(4096, "", " text mode")
           $rr.execute("YOUR_COMMAND") ;place here your command
    	EndIf
    Sleep (3000)                ;push and hold 3 sec for executing.
    WEnd
    ;AI's error reporting Object
    Func MyErrFunc()
        Local $err = $oMyError.number
        If $err = 0 Then $err = -1
        SetError($err)
    Endfunc
    Func _exit()
    Exit
    EndFunc
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Perfect thread.....Subscribed to thread
    El Camino, do you have the same code for vb.net
    I think i can create the roadrunner.sdk object like this
    Code:
    Dim rr As Object = CreateObject("RoadRunner.sdk")
    hmm, strange but neat at the same time. If i do that roadrunner starts. so what..., i would be compiling a new program that would include RR? Or a new program that would include my features but call/open RR?
    Okay tested a little more. So That will give me access to send to RR? And if my program is run without rr running, then rr will start. Otherwise RoadRunner can LOAD my program while entering a skin that would need my programs enteraction. Then you can have the skin close my program on exit.....hmmm.
    Iceman_jkh, I would love to see what you end up with. I have a program that i'm secretly working on that needs the same kind of control of RR.
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    Apr 2005
    Fresno, CA
    Hope the forum lets me double post
    Anyways after a couple seconds i can send searchs to the search box like this.
    Created a new form with button1 and textbox1
    Code:
    Public Class Form1
        Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        End Sub
        Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
            Dim i As Integer
            Dim ch As String ' must be string to send :)
            For i = 0 To TextBox1.Text.Length - 1
                ch = TextBox1.Text.Chars(i)
                rr.execute(ch)
            Next i
            rr.execute("Enter")
        End Sub
    End Class
    Simple VB.net code
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/showthread.php?t=65723
    Nov 2005
    Thanks El Camino.
    EDIT: I got it to compile - turns out it must be saved as a .au3 file before it allows compilation (DOH!)
    Basically, if the cursor becomes a text cursor, I want:
    a) Audio to mute/pause
    b) Mic to turn on
    c) Accept commands/phonetic alphabet...until;
    d) ENTER/command word is said (which is the equivalent of pressing ENTER)
    e) turn mic off - as ENTER should change the cursor back to a pointer (not text cursor).
    f) Audio resumes/unmutes
    Profit> would also love to see what you are working on (in secret :P)
    I'm hoping this little 'plugin' will make the voice control actually viable and useful!
    Cheers
    Ice
    Jul 2006
    Question ICE
    Quote Originally Posted by Iceman_jkh View Post
    Thanks El Camino.
    Can you step me through that script a little. I ve only written 1 very VERY basic script before. I couldnt even see how to get this to compile.
    b) Mic to turn on
    Cheers
    Ice
    Ice - Won't you still have to issue the "letters" command or "numbers" command since they are in the commands.cfg or could you load a different config file for just the osk ? Also, doesn't the voice module stop listening after a successful command is issued and you have to prompt again ? I know I'm asking more questions than I'm helping but wanted to think it all the way through.
    I use the voice control in mine all the time but I have a steering wheel control mapped to enable the voice prompt and then mute the mic after a set amount of time. Works out pretty well - I don't normally issue just letter and number commands because of what I asked you above.
    Nov 2005
    OK, now that I can run it , Ive managed to understand whats going on
    Heres what ive put together.
    Purely a concept at the moment. Credit goes to El Camino for the main code!
    Code:
    #Include <Misc.au3>
    $test = "test"
    $SpeechOn = -1
    While 1
    	EndIf
    	If MouseGetCursor() = 5 And _IsPressed("01") then
    		;Place code here.. to tell Voice control to listen
    	    ;$rr.execute("My_Commands")
    		$rr.execute("next") ;Just a test - so you can see it switch to the next track - delete this line in real version!
    	   $SpeechOn= 1 ; Tells the app that it is about to receive speech commands
    	EndIf
    Sleep (800)                ;push and hold for 0.8 seconds to engage Voice control
    	While MouseGetCursor() = 5 And $SpeechOn = 1
    		; While we are waiting for the speech input, we make sure that the cursor stays as a TEXT CURSOR and is in speech mode
    		; Just sit here and do nothing. This means the app will wait till the
    		; ..user finishes talking and issues their "ENTER" command
    		; Might have to add a trap for AND Not(_IsPressed("0D")) to the end of this While loop
    	WEnd
    	If Not(MouseGetCursor() = 5) And $SpeechOn = 1 Then ;As soon as the user presses ENTER or gives the ENTER command
    		$SpeechOn= 0 ; Turn off voice commanding - ignore incoming commands/turn mic off
    		$rr.execute("prev") ;Just a test - so you can see it switch to the prev track - delete this line in real version!
    		;$rr.execute("My_Commands") any other commands you wish to run
    	EndIf
    WEnd
    Func MyErrFunc()
        SetError($err)
    Endfunc
    Func _exit()
    Exit
    EndFunc
    Compile it to an autoit script.
    Hold left click for 0.8 seconds on a text box - should skip to next track.
    Pressing enter, moving cursor off text box,etc should skip to prev track.
    Basically all this does is prove that you can recognise such events and then trigger commands as a result
    Next step is getting it to control/interface to the voice commands aspect of RR.
    Ice
    Nov 2005
    Quote Originally Posted by montgomeryt View Post
    Im not that advanced at the voice control prog as you are mate.
    But reading the .xml I can see what you are asking.
    Hopefully we can create a smaller version of the .xml with only letters,numbers,etc using the grammar compiler. To be used specifically for this purpose. Even better would be causing the voice recognition to only use the mini .xml file when triggered in this way... and use the normal grammar file if invoked any other way. Get my drift?
    Could even use PowerVoice from 0l33l (i tihnk it was). All I really want is a prog that writes what I speak into the text box.
  1. voice control sw
    By TwinII in forum Software & Software Development
    Last Post: 08-18-2002, 05:15 AM
  2. voice control idea
    By crazyshaxs in forum Software & Software Development
    Last Post: 02-25-2002, 01:32 AM
  3. Replies: 22
    Last Post: 08-13-2001, 02:42 PM
  4. Voice Control
    By bjrady in forum Software & Software Development
    Last Post: 05-26-2001, 04:45 AM
  5. Voice Control for Winamp
    By Stryph in forum Software & Software Development
    Last Post: 09-15-2000, 12:20 AM
