Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 52
Thread: HD Radio Mod: Power Antenna Trigger
  1. #11
    Nov 2005
    In that case, keep the HD Radio as is, and use the ANT as a pass-through. Use the LPT port or something else to trigger when the antenna should be up.
    You could put a diode on the output of the normal headunit's power antenna signal and connect that to the wire which extends the car antenna. You would also need a signal of some kind from the HD Radio itself to know when its on. lemme think about it and get back to you. its late here.
    EDIT> do you want to listen to HD radio (via rf modulation) on the head unit when the PC is off?
  2. #12
    Vendor - Qube colin's Avatar
    Dec 2006
    There's a pin at the DIN connector that is actually called PW_ENABLE, and it goes LOW when the unit is on, high when the unit is off. You could use that signal to ground a relay which provides the +12 to your antenna. That way the antenna goes up and down with the unit's power.
  3. #13
    Mar 2007
    Nashua, NH
    Quote Originally Posted by Iceman_jkh View Post
    Nope. I will only use the HD Radio when using the CarPC. The stock headunit will only be used by itself and not with the HD Radio.
  4. #14
    Mar 2007
    Nashua, NH
    Quote Originally Posted by colin View Post
    Thanks Colin for the idea. I wonder if this pin is populated in Mitch's cable. If so, that could be wired up easily enough.
  5. #15
    Dec 2006
    I believe Mitch's cable actually sets the pin to high or low. If you take a peek at the cable or the code, he uses the DTR line I believe to drive it. A quick little hack to a single wire and you could no-doubt run a relay directly off it since it's already connected to a transistor and is not being fed by the serial port, but rather a 5v line on the HD unit itself.
  6. #16
    MySQL Error
    Oct 2004
    yep.. hmm... a good idea... it goes LOW when ON
    the transistor, could sink 100ma... so a small relay could be done
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  7. #17
    Nov 2005
    wish I knew that earlier
    Mitch> possibility to make your cables up with an antenna 'trigger' wire (tapped off that line)? Ive got my cable already, so its purely a future feature idea.
  8. #18
    MySQL Error
    Oct 2004
    antenna trigger is 12V positive, i dont got that there... it would have to be basicly open collector, you would have to supply relay...
    mitch
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  9. #19
    Nov 2005
    yes, I realise that. I meant just having a single wire that the 'enthusiast' can use to stimulate the open collector.
  10. #20
    Mar 2007
    Nashua, NH
    Exactly...I could use that right now.
  1. Way to connect to power antenna for headless unit.
    By stonestatue in forum Car Audio
    Last Post: 06-17-2007, 05:58 PM
  2. open power antenna?
    By sanbas in forum General Hardware Discussion
    Last Post: 05-29-2006, 02:33 PM
  3. Radio Antenna / Power Extension Cables
    By vatik in forum General Hardware Discussion
    Last Post: 11-17-2005, 12:21 AM
  4. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  5. Using radio antenna for radio AND tv
    By pyros in forum General Hardware Discussion
    Last Post: 05-19-2004, 02:06 AM
