Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 52
Thread: HD Radio Mod: Power Antenna Trigger
  1. #21
    Vendor - Qube colin's Avatar
    Dec 2006
    Are you willing to take apart your Mitch cable? It's a pretty simple hack if you've got a soldering iron and a small relay...
  2. #22
    Mar 2007
    Nashua, NH
    I just got this cable...and spent a long time waiting for it to arrive...but sure. I will.
    Are you agreeing a relay that draws 100ma or less is OK? If so, I will find one to use.
  3. #23
    Mar 2007
    Nashua, NH
    I am ready, willing and able to do this mod. Any more details on how to? ...and what is the max draw for the relay?
  4. #24
    Dec 2006
    Basically, you're just going to use a relay with less than say 90mA current draw (55 ohm coil or so) and hook it up to the output of the transistor in the circuit. The output is the side that is connected to the resistor (a pullup).
    So, output of transistor goes to the ground of the relay coil.
    The positive of the relay coil goes to the OTHER side of the resistor mentioned before. This is a +5 line.
    When Mitch's software enables the radio, it pulls the line low and therefore grounds the relay, making it turn on. When he disables the radio, it leaves the line open, and the pullup resistor causes the line to go positive, which would disable the coil and click the relay off...
  5. #25
    MySQL Error
    Oct 2004
    dont forget diode in reverse across coil!!!
    -Thanks
    Mitch
    www.rush2112.net
    Sun, Come shine my way
    Wind, Carry me home
    The piece of me that died
    Will return To live again
  6. #26
    Dec 2006
    Thanks, that was dumb of me to forget Don't wanna be damaging your other components right.
  7. #27
    Mar 2007
    Nashua, NH
    OK, something like this:
    The things in grey are in Mitch's cable already. I don't know if the transistor is a pnp or npn...but that doesn't really matter for the pic. I am coming off the emitter...right?
    Let me know if this doesn't look right.
    EDIT: I know I left the pull-up resistor hanging...it's for display purposes only.
  8. #28
    Dec 2006
    Well, you'd probably want to use the +5v that's on the other side of that resistor instead.
    There's not really a +12v easily available, believe it or not.
    Your orientation of the transistor is wrong too, but you've got the idea.
    Ill draw one out in a second.
  9. #29
    Dec 2006
    MitchJS's cable with the modification:
  10. #30
    MySQL Error
    Oct 2004
    meisier, you're pcboard might look differnt, but the 2 lower right points are the same...
    u still need 12v on the COMMON of the relay
    then NO goes to antenna...
    and dont forget the diode across the relay, or maybe something get spiked!
    maybe a omron G5A-234P-DC5, the G6L are cool! tiny suckers...
    its not as clean as one would wish
    the big quesion, is maybe the extra pin on the 4 pin molex could be pwr antenna
    not sure what that used pin is doing... could look
    -Thanks
    Mitch
    www.rush2112.net
    Wind, Carry me home
  1. Way to connect to power antenna for headless unit.
    By stonestatue in forum Car Audio
    Last Post: 06-17-2007, 05:58 PM
  2. open power antenna?
    By sanbas in forum General Hardware Discussion
    Last Post: 05-29-2006, 02:33 PM
  3. Radio Antenna / Power Extension Cables
    By vatik in forum General Hardware Discussion
    Last Post: 11-17-2005, 12:21 AM
  4. del
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  5. Using radio antenna for radio AND tv
    By pyros in forum General Hardware Discussion
    Last Post: 05-19-2004, 02:06 AM
