Results 1 to 6 of 6
Thread: Multiple commands from your Radio Preset buttons
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Has anyone come up with some code that allows multiple commands to be called from the preset button.
    What I am trying to do is have 12 presets, 6 FM and 6 AM. Which would be assigned to only 6 buttons. FM presets would be active when the FMAM indication is OFF, and AM when FMAM indicator ON.
    Code similar to this.
    BYIND;FMAM;FMPRESET;PRESET1<<FMPRESET;PRESET6
    This code does not allow you to add the station to the preset button, but does switch to the preset when in either FM or AM according to the indicator.
    I would like to be able to add to the preset button as if it was this code.
    FMPRESET;PRESET1
    This would also allow for multiple presests, tons of them. My Head Unit allows multiple presets to only a few buttons. I have FM1, FM2 FM3 and AM.
    This is what I am trying to do.
    ANY IDEAS, PLEASE....
    New Age Garmin - Skin for RR
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Add a button hold command to the button and it should work...
    Code:
    "BYIND;FMAM;FMPRESET;PRESET1<<FMPRESET;PRESET6",@BYIND;FMAM;!FMPRESET;PRESET1<<!FMPRESET;PRESET6"@
    Ride Runner RR's Myspace
    Aug 2006
    West Allis, WI
    Thanks I will give this a try tommorrow when I have more time.
    Guino, allways a help...
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Quote Originally Posted by guino View Post
    Code:
    !FMPRESET;PRESET1
    Dam! That's heckava a lot simpler than the script I wrote to access the press & hold function when using "FMPRESET" on a button.
    Thanks G!
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Aug 2006
    West Allis, WI
    Thanks alot guino works great.. DID have to modify it slightly figured typo on your end...
    Any way here is the working code.
    Code:
    "BYIND;FMAM;FMPRESET;PRESET12<<FMPRESET;PRESET6",@BYIND;FMAM;!FMPRESET;PRESET12<<!FMPRESET;PRESET6@,
    guino's Avatar
    Nov 2004
    Toronto, Canada
    your first post also had it as "1" instead of "12" -- I really just copied/pasted it :P
  1. MP3 Player to GM Factory Radio
    By thewams in forum Newbie
    Last Post: 04-01-2007, 03:46 PM
  2. radio preset under 87.9
    By adminif in forum RR Bug Tracker
    Last Post: 04-25-2005, 04:39 PM
  3. Replies: 0
    Last Post: 03-20-2005, 02:34 PM
  4. Where To Buy Buttons, Switches, Lights?
    By eCarô in forum General Hardware Discussion
    Last Post: 02-22-2004, 03:25 PM
