Results 1 to 10 of 18
Thread: Move files...
    Jun 2003
    Memphis - TN
    Move files...
    Heres what I'd like to do if its possible.
    I separate my music that I like in folders by genre. I have alot of music, but some of it I dont care to have to scroll through trying to find a song to listen to. I usually copy alot of it over to the PC and separate the ones I like into folders then delete the remaining. Doing this, I sometimes put it in the wrong folders, not realizing until Im listeining to that folder's music.
    I would like to create a button that opens a popup menu, from that each button on a menu will copy the current selected song to a pre-determined folder. That way I can use it to sort my music that may be mis-sorted, as well as copy new music to specific genre's folders and eliminate the unwanted music.
    I though about just creating an autoit script for each button, but I dont know how to tell the script to move the curent selected song.
    Doable? Suggestions?
    2011 Nissan Frontier SL
    AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
    OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Suggestions....
    Don't seperate music by genre(makes no sence to me and others..)
    Yes i could be done... what skin are you using BTW?
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2003
    Memphis - TN
    Brushed metal, modified BMWE26's version how I wanted it.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Here's my autoIT script to move the current selected song to a RR defined folder variable $destinationmedia$
    If you have any of Sonicxtacy02's plugins installed, the script will reuse the "SUCCESS" & "FAIL" skins for popup confirmation.
    Hope that helps you out.
    Attached Files Attached Files
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Jun 2003
    Memphis - TN
    thanks! may I ask which plugins your referring to? The ratings plugin?
    Also, where do I specify the variable?
    ExecTBL.ini in the RR directory, or the skin directory?
    Aug 2006
    Sun Diego
    Quote Originally Posted by Custommx3 View Post
    For sure, the New Hits plugin has the "SUCCESS" & "FAIL" skins. I'm not sure about the ratings plugins.
    In any case, you can define the destination folder path in rr.ini, skin.ini or SETVAR;destinationmedia;<PATH> in RR.
    i.e.
    destinationmedia=E:\my_mp3\
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    mp3Copy plugin has those.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    ratings doesnt.. mp3copy and new hits do
    Live mp3Car Facebook Chat
    Jun 2003
    Memphis - TN
    well,
    I used the script above, changed the command of "filecopy" to "filemove" (I dont want to copy, I want to move obviously. Compiled it and put it in my skins directory.
    In my Audio_player skin I added
    B24,208,498,71,92,"MENU;copy.SKIN",
    In my skin folders EXECTBL.ini
    "altmusic","RUN;c:\program files\road runner\SKINS\MySKIN\altmusic.exe"
    in my copy.skin I have currently 2 buttons
    B,257,283,219,81,"altmusic",
    B,92,373,331,103,"CANCEL",
    Doesnt work .. help
    Woodbridge, VA
    Blog Entries
    55
    you want the command to read something like this barry
    Code:
    "altmusic","SETVAR;destinationmedia;C:\||RUN;c:\program files\road runner\SKINS\MySKIN\altmusic.exe"
    you need first set the path as a variable.. then you run the script. So say if you wanted 5 different buttons for five different paths you'd just create 5 buttons with the exact code above.. but changing "C:\" with whatever path you wish the file to be moved to
  1. Service Configuration Files
    By Phatsacks in forum WinNT Based
    Last Post: 08-30-2007, 12:03 AM
  2. Mirror Files
    By guino in forum Road Runner
    Last Post: 03-02-2006, 02:40 PM
  3. I Have Voices!
    By Andywaite in forum FreeDrive
    Last Post: 01-18-2006, 06:07 AM
  4. Complete set of PSD's Files
    By MickW in forum RR Skins
    Last Post: 01-06-2006, 03:13 AM
  5. Replies: 2
    Last Post: 09-08-2004, 07:07 PM
