Results 1 to 9 of 9
Thread: cant adjust volume
    Oct 2006
    Coconut Creek, FL
    cant adjust volume
    hi, im newly installing a carpc and testing my computer b4 putting it in the car. the only bug that i seem to be having is that when i first start RR, i can't lower or raise the volume until i mute and then unmute it. then it lets me adjust the volume up until i turn RR off again. At restart, same problem presists. The default volume starts at 50%.
    Is there a way to fix this?
    2000 BMW 323i
    Carputer Installed:
    Lilliput EBY701 Screen
    Centrino Duo Laptop
    1.5GB RAM
    120GD HD
    iBus
    Centrafuse 2.0
    Dec 2006
    The only thing i can suggest is to change the map master volume setting in page 2 of the config.
    You could try another install of RR to a different directory to see if you get the same problem, if it does try reinstalling the sound card drivers.
    Maximum Bitrate v8 scimitar's Avatar
    Jan 2005
    Scotland
    you have the volume set to be adjusted by gps in the rr.ini, take that off and you will be able to adjust the volume as per normal.
    Visit my site V8 Scimitar
    SP13000, 300GB SATA HD, 1GB DDR. Opus 150, K301 screen, Cisco WIFI, AQmax GPS, RoadRunner and FreeDrive, Sony MEX-R5 head unit. 4 years installed and it just keeps running!
    Dec 2007
    Boulder, CO
    I dealt with this too. Took me a bit to realize it had to do with the GPS speed thing... Is there a way to have RR do both? Meaning, have it so I can adjust the volume however I want (somedays louder, some days more chill) and the volume will raise according to speed from THAT starting point rather than a preset point?
    Jan 2005
    Scotland
    yep press mute or put your pc through a head unit
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    Quote Originally Posted by ghanchi View Post
    This is a skin related issue. I had this problem in my skin, up until recently.
    New Age Garmin - Skin for RR
    Oct 2006
    Coconut Creek, FL
    Quote Originally Posted by v8 scimitar View Post
    thanks, it was this. its fixed now.
    2000 BMW 323i
    Carputer Installed:
    Centrino Duo Laptop
    1.5GB RAM
    120GD HD
    iBus
    Centrafuse 2.0
    Oct 2004
    St. Louis area
    Quote Originally Posted by ThunderStick View Post
    Skin related issue? what'd you do to enable both auto and manual control??? From my searches so far, I thought it was built into RR...so was a RR issue.
    Toyota Tacoma Install
    BMW 325Ci Install - Old
    ZOTAC H55-ITX, Intel i3 & 320 Series SSD
    7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
    Win 7, RR, Garmin, DashCmd
    Morel Elate 9 3way & IDQ10 ported (active 4-way),
    JL Audio HD Amps, Audison BitOne.1
    Jan 2005
    Scotland
    Its not an issue its a feature, all you have to do is set it to what you want either GPS controlled or manual controlled. Personally I use GPS controlled and it works well for me but I can see it being a problem if you dont have a head unit so you set it to work manually.
  1. Adjust TV Volume without adjusting Radio Volume?
    By TheJuggler in forum StreetDeck
    Last Post: 08-08-2007, 02:45 PM
  2. Volume problem with RR.
    By Outsider787 in forum Road Runner
    Last Post: 08-01-2007, 02:45 AM
  3. Volume will not adjust, mute doesnt work
    By djjerdog in forum StreetDeck Bug Reports
    Last Post: 06-28-2007, 10:49 AM
  4. Anyone have/used a E-MU 0202? (want to adjust input volume via windows)
    By XxAndyxX in forum General Hardware Discussion
    Last Post: 06-07-2007, 07:54 PM
  5. Adjust Microphone volume
    By pijo1971 in forum PhoneControl
    Last Post: 03-29-2006, 12:28 PM
