Results 1 to 3 of 3
Thread: New RR Version - GPS Not Working
    Feb 2006
    New Jersey
    Ever since I upgraded to the 12/6 version of RR, I cannot get GPS to work. Now when I click the GPS button, it does nothing at all. The only way I can get it to do anything is to set gps to external... But when I have it set to MapMonkey.. when I click the GPS button it doesn't do anything at all..
    Anyone else have this issue?
    Just reverted back to the November version.. GPS working fine again.. this IS a bug in the new December version...
    Feb 2006
    New Jersey
    Anyone else have this problem???
    Oct 2004
    St. Louis area
    Quote Originally Posted by mnetwork View Post
    yes I had this problem too. I thought it was a problem with Xport not starting up, but when I'd bring up Xport, it was working fine. But i did notice that RR was supposedly using it's assigned port from Xport even thought it wasn't working in RR. I'm not sure what fixed it, but it's now working after a few days of not working.
    In my case, RR isn't shutting down properly with this new version. RR shuts down and resumes properly when I shut down the computer manually in windows. But if I turn off the car and turn it back on (and let the system shut down on its own), then RR is not resuming from when I last turned off the resumes from the last point where I had manually shutdown windows. since I've never had this problem in the past (and the GPS problem too), it makes me believe that they are related somehow. maybe RR didn't shut down the port properly???
    Hope it helps give you somewhere to start looking...
    Toyota Tacoma Install
    BMW 325Ci Install - Old
    ZOTAC H55-ITX, Intel i3 & 320 Series SSD
    7" Lilliput 669GL, M4-ATX, SB X-Fi, XMPCR
    Win 7, RR, Garmin, DashCmd
    Morel Elate 9 3way & IDQ10 ported (active 4-way),
    JL Audio HD Amps, Audison BitOne.1
  1. Replies: 353
    Last Post: 08-24-2009, 10:31 AM
  2. RC4 Phoco issue / SE K800I
    By SOS in forum CF Bug Reports
    Last Post: 10-15-2006, 03:34 PM
  3. Replies: 0
    Last Post: 09-23-2006, 09:38 PM
  4. RR forgets GPS port!!!
    By eduardovdr in forum Road Runner
    Last Post: 07-17-2005, 06:11 PM
