Results 1 to 3 of 3
Thread: Internal player position
    Nov 2005
    Austria
    Hi
    Does anybody know, how to setup the videoscreen-position of the internal player? I want to place it on the second screen (dualscreen) per cords.
    I know it is possible per VB-code (position of the frmMP), but I don't find any settings for that in rr.ini.
    Also the actual sourcecode-HP is down at the moment, so I can't do that with the actual code. Can anybody help?
    thx
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You probably need to look into the dualmon options... I myself have never used it.. but idealistically if you want video on the 2nd monitor while using RR on the first screen, you should probably run two copies of RR using /2 in the command line one positioned at the first screen and the other on the 2nd screen (defined on general.ini of each skin). The current sources are not available, but BlueZX3 has earlier versions on his site. If you make some change/option for playing only the video on the 2nd screen, feel free to send it to me and I'll include to the main sources.
    Ride Runner RR's Myspace
    Nov 2005
    Austria
    Thx for the info.
    Here is the update (only for build in player):
    www.quickmic.at.tt/Public/RR_DualMon_Video.rar
    All changed sourcecode-files are included. The lines I added/removed are marked with 'quickmic
    The rr.ini has now 4 additional lines in the video-section. There the position-settings of the video-screen can be adjusted.
    I hope there are no errors...
  1. rca is going to kick *** with this player ....
    By KING ZOMBIE in forum General MP3Car Discussion
    Last Post: 07-14-2000, 08:51 PM
