Results 1 to 5 of 5
Thread: CDRIP Problem
    Nov 2007
    CDRIP Problem
    I am working on getting my carputer setup but I'm having an issue with CDRIP
    I installed it with presetup.bat and tested it with an IDE CDRom that I have. It detected the CDRom in the cdripcls.ini and worked perfectly. Then I switched to the USB DVDRW that I will be using in the car and it doesn't work. The DVDRW doesn't show up in cdripcls.ini and if I delete the ini file it is NOT recreated when I restart cdrip (If I switch back to the IDE CDRom it is created immediately on starting the program and the IDE CDRom is added).
    The USB DVD Drive I am using is a Pioneer DVR-K05 enclosed in a mo-co-so USB Enclosure.
    I have tried everything I can think of (I am a PC Technician so I've tried all the common things)
    The DVR-K05 works fine with audiograbber in ASPI mode and the DVR-K05 is supposed to be fully ASPI compliant.
    I have tried manually editing the cdripcls.ini file using the hardware id in device manager but nothing. I have been through all the FAQS as well as searching the site and looking at EVERY post with either CDRIP or cdripcls.ini in it.
    I really don't know what else to do. If you have any ideas I'd really appreciate it.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    I do know that the CDRIP plugin is like very old and hasn't been updated in a long time.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    Nov 2007
    Are there any alternatives that have been integrated into RR?
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    I have seen the CD-RIP not like USB drives in the past -- normally this is some sort of ASPI issue though... if you're saying the same hardware setup works on audiograbber (in aspi mode -- not in analog), then it should work virtually the same way in the CDRIP.
    Ride Runner RR's Myspace
    Nov 2007
    Yeah, I checked the mode in audiograbber and it works perfectly. Any one have any other ideas?
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. MC2.0 skin and CDRIp
    By Angelus in forum Road Runner
    Last Post: 01-05-2006, 07:49 PM
  3. Replies: 2
    Last Post: 01-05-2006, 05:04 AM
  4. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
  5. had an all day (9 hr) problem at work....
    By wizardPC in forum Off Topic
    Last Post: 10-20-2005, 12:50 PM
