Page 1 of 5 12345 LastLast
Results 1 to 10 of 46
Thread: Someone please help - RR not saving song on exit
    Mar 2006
    NY
    I've been having this problem for almost a year. I figured something was wrong with my system but I did a full XP reinstall and reinstalled the latest rr (12/13) along with winamp 5.13. Note that when I first had the carpc it did work properly.
    The problem: RR will more often than not lost the songs in the playlist on exit. For example, I start with a blank playlist, browse to an album and add all the songs. I now have an "on-the-go" playlist. Everything's going well but when I exit road runner (usually by standby but even just exiting normally) and resume, either
    1. the playlist is empty
    2. the playlist is still there but instead of resuming playing music where it was, music is stopped and the song selected is one that was playing a few songs before I exited
    3. it works as it should (very, very rarely)
    Is there anyone that might know what's going on or is there anything I can put in exectbl to force rr to save the current location on exit/standby and force it to reload the saved position on reload? I primarily use standby for 2 hours and then a hard off.
    Anyone out there know what's going on? This is like the last hurdle to overcome having a great, fully functioning system and I promise not to mess with it any further if I get this working... haha.
    TIA!
    Chris
    Nov 2006
    It may be caused by a com port not closing correctly, stopping RR from saving the resume.ini file (and any other changes). Try unplugging any usb devices that you can, or anything else using a com port and see if things work. If it works, then try isolating which one is causing the problem and check drivers. I was having a similar problem caused by a serial to usb adapter.
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    Is there a way to actually diagnose the problem rather than just unplugging a bunch of stuff and hoping that it can be isolated?
    Low Bitrate lor109's Avatar
    Mar 2004
    Did you mess with the Hibernate aware Setting in RR.ini? Not sure if this applies, but putting hibernateaware=false in my ini solved a similar problem for me.
    Mar 2006
    NY
    I didn't change it from the default hibernateaware setting. I will try both suggestions a little later today and let you know.
    Would the hibernateaware setting and the suggestion regarding USB devices/com ports affect just exiting roadrunner and not even going into standby? Because it loses the playlist even when just exiting and reloading the skin
    Mar 2006
    NY
    ok, just tested both suggestions and unfortunately neither one fixed the issue. I changed hibernateaware to false and also tried running with nothing USB except the mouse. Still won't save my current playlist on exit.
    I dont know what the values in resume.ini correlate to but for reference here's what it currently is:
    -1
    -1
    false
    false
    path of skin here
    0
    false
    false
    false
    false
    That mean anything to anyone? I have resume music set to always in rr.ini.
    Jun 2007
    You probably should post your entire rr.ini file.
    Mar 2006
    NY
    Quote Originally Posted by Machinehead View Post
    A good idea!
    Here's my rr.ini
    [General]
    winamppath=C:\Program Files\Winamp\
    hidewinamp=false
    launchpath=Click here to set path
    startcommand=
    voice=false
    disableinternat=false
    exitmute=false
    showicons=false
    showextensions=false
    hidemouse=false
    hidetaskbar=true
    hidedesktop=false
    hidedots=false
    gpstime=false
    gpsusadate=false
    exitmode=0
    dateformat=MM/DD/YY
    timeformat=HH:MM AM/PM
    locale=0
    screentype=16:9
    debugmode=false
    enableclipping=true
    nozoom=false
    usegestures=false
    leavemousealone=false
    closeapps=false
    fastmode=-1
    usedualmon=false
    soundcard=0
    screenlimit=3
    mastervolmap=0
    forcehibernate=false
    hibernatereload=false
    usbsound=false
    browsertype=1
    browserpath=C:\Program Files\Internet Explorer\iexplore.exe
    usevoicecontrol=false
    usecar2pc=false
    fadeinvolume=true
    [Skins]
    skinpath=C:\Program Files\Road Runner\Skins\LSX VOID 3.0\
    transition=-1
    backgroundpath=To set path,Click --->
    [Gamma]
    gammamode=3
    gpsgammamodeoffset=0
    gammaday=0:0:0
    gammanight=-50:-50:-50
    gammadaytime=1:00
    gammanighttime=1:00
    autogammamode=2
    autoskinmode=1
    [Preload Screens]
    preload=
    [Music]
    musicpath=C:\Music\
    playlistpath=Click here to set path
    useid3=2
    showid3playlist=true
    showid3browse=false
    lazytag=false
    singleclickaudio=false
    noformat=false
    listnumbers=true
    listfollowssong=true
    resumemusic=2
    audiorepeat=last
    audioshuffle=last
    id3listformat=%title%
    id3browseformat=%title%
    titlesafter=-
    albumart=*.txt
    fadeimages=true
    audiofiles=.mp3, .exe
    visuname=!Winamp Gen!AVS
    scrollmode=1
    circularlist=false
    groupnumbers=false
    picspath=To set path,Click --->
    [Radio]
    radiomode=0
    allowallfreqs=false
    radioline=0
    userbds=false
    [XM]
    xmport=0
    xmline=0
    xmlineinplugin=false
    xmtype=0
    singleclickxm=false
    xmformat=%station% %artist%
    [SIRRIUS]
    srport=3
    srline=4
    srlineinplugin=true
    srlineinpar=line://title=SIRIUS,srate=44100,bps=16,nch=2
    singleclicksr=false
    srformat=%artist% - %title%
    [Video]
    videopath=C:\Movies\
    mpcpath=C:\Program Files\Road Runner\
    videoautohide=true
    videohidetime=4
    builtinvideo=true
    videofiles=.mov, .avi, .mp4
    videoshuffle=false
    [TV]
    tvline=9
    [GPS]
    gpsmode=2
    mapmonkeypath=Click here to set path
    gpspath=C:\Program Files\iNav\iGuidance\iGuidanceUMPC.exe|nowarning
    gpsname=iGuidance
    overspeed=55
    gpsport=8
    mappointmap=1
    mapcountry=United States
    mapcity=
    mapautozoom=true
    isunits=false
    usegpsserv=false
    gasfinderautorefresh=false
    mapvol=5
    [IG Native]
    ignative=true
    igautosw=true
    gpsonvoice=true
    pauseonvoice=false
    lastscreenswitchtime=5
    [Speed Att Vol]
    speedatt=false
    [Phidget]
    phidget1=0
    phidget2=0
    phidget3=0
    phidget4=0
    phidget5=0
    phidget6=0
    phidget7=0
    phidget8=0
    [4 Temps]
    tcomport=0
    tempscale=c
    temp1=c
    temp2=c
    temp3=c
    temp4=c
    [Volt Meter]
    vcomport=
    [Phone]
    phoconodesign=false
    motophone=false
    phonelistspath=Click here to set path
    contactspicturespath=Click here to set path
    ringtone=Click here to set path
    smstone=Click here to set path
    maxcalllistentries=100
    phoconoincallevent=false
    connecthsp=1
    standardphonebook=0
    phonebooksencoding=windows-1252
    [Weather]
    cityweather=
    weatherunits=USA
    weatherdegress=∫
    localdatacaptureinterval=0
    [Extra's]
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Try this.
    Run RR and play whatever you want for a minute or 2.
    Close RR and let it shut down completely.
    Restart RR and let see if the music resume where it left off.
    If it does,there is a problem somewhere with your standby/hibernate setting.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    resume.ini line descriptions:
    -1 (if audio is playing at time of exiting, this is the list position that is currently playing)
    -1 (current track position)
    False (repeat T/F)
    False (Shuffle T/F)
    path of skin here (current skin path)
    0 (SpeedAttBaseVolume)
    False (VideoShuffle)
    False (?)
    False (?)
    False (?)
    The first line tells me that WA was/is stopped, values are -1=stopped, 4=playing or paused
    Second line is the song position, and if WA is paused when exiting there is a "-" infront of the position..
    Don't know why your line 5 doesn't have the currently used skin path??
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
  1. Replies: 16
    Last Post: 07-29-2007, 03:57 PM
  2. Why does RR cut song names off?
    By Ub312g0d in forum Road Runner
    Last Post: 04-28-2006, 12:52 PM
  3. IE in RR bug
    By accentsound in forum RR Bug Tracker
    Last Post: 07-10-2005, 02:21 PM
  4. Don't exit winamp on RR exit?
    By anitanium in forum Road Runner
    Last Post: 06-27-2005, 11:48 PM
  5. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 12:55 PM
