Results 1 to 4 of 4
Thread: RR gamma
    May 2005
    Monterey, CA
    Question RR gamma
    I tired to using the builtin gamma but it doesn't seem to do anything. I tried with using gps or set time, nothing. I tried with a exturnal app, same thing. If I run the app manuelly it works.
    Any help?
    May 2005
    Monterey, CA
    Any help with getting the gamma to work, I really need this.
    Maximum Bitrate Valheru's Avatar
    Jul 2007
    Ireland
    if you use built in gamma, the settings are stored in the "skin.ini" file within whatever skin you are using. check these first.
    if you use ext app, your skin must manually call the gamma change if you don't have it set to auto change gamma based on time !
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by Valheru View Post
    if you use built in gamma, the settings are stored in the [HL]"skin.ini"[/HL] file within whatever skin you are using. check these first.
    You probably meant "general.ini"
  1. RR Newb... need help/suggestions.
    By Nola111 in forum Road Runner
    Last Post: 03-12-2007, 08:10 PM
  2. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  3. Dialup in RR without Phoco?
    By kbreeden in forum Road Runner
    Last Post: 12-12-2005, 09:04 PM
  4. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  5. Bruno Speech Recognition with RR?
    By ruairi in forum Road Runner
    Last Post: 05-03-2005, 01:20 PM
