you could use the "reloadskin" command and it will exit all embedded apps but keep RR open.
Hi,
Is there a standalone command that will close all embeded/external apps, just like what happens when you exit RR, but without actually having to close RR
I want to run this command prior to hibernation to reduce the memory usage and hibernation filesize.
beer replenishment fund
mp3car live search
Only downside to using that cmd is that you would loose any preloaded screens.
Current Project: DFXVoice [Beta Released]
Next in line: RRMedia v2.0
DFX 5.1.1 Skin
Appstore Link
My RideRunner Plugins
RRMedia
RRExtended
DFXVoice
And Id have to wait for the Fade-in and startup sounds/sequences.
Is there any cleaner or more specific command?
How does RR do it according to "Close all embedded apps on exit" on RR config?
(This question is tying in with my other thread about hibernating. I want to free up as much mem/resources as possible before hibernating, so that resuming isnt too CPU intensive. Resuming with voicecontrol running seems to choke my 512MB - 2.2Ghz C2Duo for a few seconds on resume - and sometimes crash it, even though there is only ~280MB memory in use. Being able to kill/load voicecontrol separate to RR would be even better actually!!)
You can use the ONSUSPEND command in your exectbl.ini file to kill applications.
"ONSUSPEND","CLOSEWINDOW;iGuidance||CLOSEWINDOW;What ever Name"
that will close all your external application running.
Then you can use the ONRESUME command to start them up again.
SORRY TO BRING BACK AN OLD THREAD, BUT I BEEN HERE PICKING AT MY NON PROGRAMMING SKILLED BRAINS FOR HOURS. I DID DOING ALOT OF SEACHING BUT IS CONFUSED AS HELL HOW TO CLOSE OPEN EMBEDDED APPS IN RR. WHAT I NEED IT TO TO IS CLOSE UPON GOING INTO HIBERNATION. I HEAR A LOT ABOUT EXECUTTBL.INI FILES BUT WHAT THE FREAK DO I DO WITH A BLANK FILE???? I TRIED PLAYING AROUND AND PUTTING IN SOME CODES BUT NOTHING WORKS. SOMEONE PLZ SHOW ME THE LIGHT. THANKS IN ADVANCE.![]()
Closing you embedded apps before hibernation will NOT reduce the hibernation filesize.
The hibernation filesize is always the same as the amount of memory you have in the the PC.
It may possibly reduce the amount of pagefile thatis used, but that won't affect boot up time.
thanks but that was not the purpose of me doing so... my nav soft for some odd reason will not detect my gps puck upon resuming unless it is closed before hibernation. Also I embedding an game emulator but it will not close when I exit from the screen (I want it to close when I switch to a different screen in RR.)
I was replying to the OP, hence I quoted him.![]()
There is a CloseWindow command in Road runner.
From the SKinCommands.txt:
With the above, you can create a entry in the exectbl.ini something like this:"CLOSEWINDOW" - This allows you to close any running application based on the given window title. The application may request the user to save any unsaved data before closing, so beware.
Example: "CLOSEWINDOW;Notepad"
"CloseAllApps","CLOSEWINDOW;WinAmp||CLOSEWINDO W;iGuidance"
In the above example, there are just 2 apps to close. You can append as many as you want on that command.
Then on your EXIT button in the skin, you could use "QUIT||CloseAllApps"
My Fiero Build Thread
