Results 1 to 5 of 5
Thread: windows power options disabled?
    Dec 2006
    maine
    I've been fussing with this for a few days now.
    It seems that whenever RR is open, the windows power options i set arent effective. I diddnt see anything in the rr config about disabling them, so I just assumed they'd take effect.
    The problem here, of course, is in my setup, the juice to the computer is cut when ACC is cut- the computer is a laptop, so it just switches to its internal battery- I was depending on the power management to put the machine into standby (i had it set to 1 minute) after the car is off.
    As it stands, the computer doesnt turn off, it just runs until the internal battery is flat, at which point this machine hangs, and i have to go pull the battery to reset the unit and get it started again.
    As for now i'm just manually putting the machine into standby every time i turn off the car- not acceptable!
    Is RR disabling the windows power management? Is this a known issue? Is there a page in the config i'm just not seeing?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    If you don't open RR and turn off the car, the laptop does go into standby? Only thing that I can think of that would prevent it from going into standby would be because of communication to an open port, like GPS.
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR is unaware of power management procedures and if the system is set to suspend/hibernate after a certain period of inactivity, RR should be merely notified of such and take action to prepare for the event, without interfering with it. However, ports and any other running applications may interfere/disable the process.
    Ride Runner RR's Myspace
    Dec 2006
    maine
    Yes, if RR is closed it seems to shut down fine.
    Most likely GPS, as you said- i tend to leave the gps screen open, as its all i really wanted the damn thing for.
    Is there any way i could get around this? maybe if i put the gps power on a relay that cuts with the car... I'll try unplugging the gps tomorrow and seeing if it times out and goes to standby...
    Mar 2005
    any updates?
  1. Centrafuse and Windows Power Setting Conflict?
    By d0tech in forum Centrafuse
    Last Post: 06-25-2007, 04:18 PM
  2. 1970 Standard beetle, options for more power?
    By digibug in forum Power Supplies
    Last Post: 04-20-2006, 04:14 PM
  3. Windows Vista W/nView!
    By 97GST in forum Operating System Optimization
    Last Post: 04-01-2006, 08:46 PM
  4. Options to power 15" desktop LCD from 12vdc
    By MVShibui in forum Power Supplies
    Last Post: 04-01-2005, 07:31 PM
