Results 1 to 10 of 19
Thread: Voice control crashing RR on resume
    Nov 2005
    I wanted to put this in a new thread, rather than the old "Voice Control embedded in RR" one.
    My RR crashes pretty consistently (90%) upon resume if I have Voice Control enabled. (Intel DG965SS + E4500 + 512MB ram)
    Is anyone else experiencing this (and possibly not attributing it to Voice Control)? If so, try disable VC and see if theres a difference.
    Hopefully we can figure out what is crashing and rectify it. I really want to use voice control on my carpc.
    Is there anyway to unload VC upon hibernate and re-load it upon resume?
    I know I can 'disable' it, but that didnt improve the crash rate.
    Ice
    Dec 2007
    it didn't crash my crappy umpc... I've been playing with it lately and really enjoy talking to it... Didn't crash not even once... However, i have my own issue... Iceman, how are you dealing with the problem of it listening to itself... When music is on, it's going nuts...
    Nov 2005
    havent even addressed that issue yet, as I cant get it to resume successfully .
    Until such time that it works on resume all the time, Im not gonna bother working on it anymore.
    J
    Dec 2007
    Hey you probably have done this already.. but let's make sure... I don't know if u have same version as mine.... put all of the files in RR root and register voiceControl.dll..
    Before you register, unregister what you have already for clean install... And enable the VC in RR.ini of course.. then launch RR and see what happens...
    Good luck..
    Attached Files Attached Files
    Nov 2005
    I think I have that one already. But I'll try it anyway - anything to get VC working
    Will report back.
    Nov 2005
    Nope. Got round to trying it. Still crashes RR.
    Perhaps a new version may come out in the future.
    Gotta switch to something else for now I think.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    RR doesn't do anything (handling wise) to the voice control object when hibernate/resuming -- if it doesn't crash when not using voice control, sounds like it could be an issue with either the plugin itself or M$ speech (or both). You can try to add a delay when resuming from hibernation to see if it gives time to re-set the speech objects in M$'s side -- you could try that by running a small command/script with RUNW in the ONRESUME event.
    Ride Runner RR's Myspace
    Nov 2005
    Thanks for clearing that up Guino.
    Is there any way to delay RR's access/use of the speech engine?
    Like disabling it (causing it to ignore speech) for a while.. and then turning it back on after say 5 seconds.
    I do currently have a delay set, so that the PC waits for RR to be ready, then waits for winamp, then waits for a third party app. Perhaps 2-3 seconds all up, but the voice control crashes just after windows resumes, and it crashes RR, not just the voice aspect. Probably cause RR is loading the voice DLL.
    guino's Avatar
    Nov 2004
    Toronto, Canada
    you should probably make a .bat file to run with CMD.EXE containing tha PAUSE command... then put it on exectbl as the ONRESUME event.. then resume and wait a few seconds before pressing any key to continue... if it crashes after that anyway (or without pressing), chances are that something is wrong in the voice control dll itself, if not, see how many seconds you need to wait in order for it not to crash...
    c:\pause.bat :
    pause
    ExecTBL:
    "ONSUSPEND","RUNW;CMD.EXE|/C c:\pause.bat"
    One Sharp Cheddar ThunderStick's Avatar
    Aug 2006
    West Allis, WI
    It allmost sounds like his DLL is not registering properly. I can get RR to crash if I enable voice control from RRCOnfig before registering the DLL.
    New Age Garmin - Skin for RR
  1. RR Doesn't Resume Music after Hibernate
    By Wiredwrx in forum Road Runner
    Last Post: 03-24-2008, 05:08 AM
  2. Replies: 7
    Last Post: 01-08-2008, 01:44 AM
  3. Set RR resolution on resume from hibernation?
    By htsource in forum Road Runner
    Last Post: 08-08-2007, 04:05 PM
  4. RR won't resume after hibernate
    By swift_gti in forum Road Runner
    Last Post: 02-25-2007, 11:21 PM
  5. RR keeps crashing using Volume Buttons!
    By badfish25 in forum Road Runner
    Last Post: 11-08-2005, 01:17 AM
