Results 11 to 20 of 29
Thread: RR and mappoint
  1. #11
    ndg
    ndg is offline
    Feb 2008
    Mappoint problem
    I can not get Mappoint 2006 to work on the latest version of Roadrunner (downloaded yesterday). When I click GPS nothing happens.
    On a 4/2007 version of Roadrunner I have installed, Mappoint 2006 loads fine when clicking GPS.
    I'm using alpine blue skin on both and both rrconfig settings appear to be the same.
  2. #12
    Dec 2007
    Luray, VA
    MapPoint and the latest RoadRunner
    I am also having an issue with the Late December RoadRunner. I originally built the computer and installed the early December version RoadRunner. I hit the GPS button and MapPoint loads just fine. I reloaded RoadRunner that came with the new Config utility supporting the HD Radio and now the button doesn't do anything at all. I did a clean install with no modifications or add-ons with no luck. I tried the MapPoint radio button and External with no difference. Any suggestions are welcome.
    Hardware:
    Via EPIA-M1000
    1Gig memory
    60Gig Laptop HD
    Wireless, USB Bluetooth
    Visteon HD Radio, Mitch’s interface cable
    M2-ATX power supply
    Lilliput 7” touchscreen
    2000 BMW 323i PC Project
    Planning:
    [----------] 99%
    Purchasing:
    [----------] 99%
    Software/Hardware debugging
    [----------] 75%
    Installation/:
    [----------] 90% ibus and OBD2 next
  3. #13
    Maximum Bitrate Mañana's Avatar
    Jul 2004
    Sweden
    I'm having the same issue as the poster above...
  4. #14
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    >>TEST WITH THE BMV2 SKIN<<
    Then ONLY IF IT WORKS, test with other skins -- A LOT of skins don't support mappoint.
    If it doesn't work with the BMV2 skin: post the file properties dialog of MappointControl.ocx from mappoint's install folder.
    Ride Runner RR's Myspace
  5. #15
    Jul 2004
    Sweden
    I tried with BMV2, same thing... I also attached my rr.ini
    Attached Files Attached Files
  6. #16
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Interestingly enough, the version is the same but the file size is NOT the same.
    I'm assumming MS changed something for the Europe version.. I'll PM you with some next steps..
  7. #17
    Dec 2007
    Luray, VA
    MapPoint and RR
    I also tried the BMV skin with the same result. GPS button does nothing. I wasn't able to take a snapshot but I have the information from the properties screen. I am using MapPoint North America.
    MappointControl.ocx
    General Tab:
    Size 354kb
    Size on Disk 356kb
    Created Tue March 28 2006
    Version Tab:
    File version 13.0.12.1000
    Thanks for the help
    Dean
    Hardware:
    Via EPIA-M1000
    1Gig memory
    60Gig Laptop HD
    M2-ATX power supply
    Planning:
    [----------] 99%
    Purchasing:
    [----------] 99%
    [----------] 75%
    Installation/:
    [----------] 90% ibus, XM, and OBD2 next
  8. #18
    Dec 2007
    Luray, VA
    MapPoint
    That did the trick Guino. Everything works great now.
    Thanks again
  9. #19
    ndg
    ndg is offline
    Feb 2008
    Fix?
    Could the steps that fixed the problem be posted?
    Dec 2007
    bump for ndg's request, mine does not work either with North America Mappoint 2006 and the latest roadrunner.
  1. Auto start Mappoint when RR starts?
    By Zogg in forum Road Runner
    Last Post: 10-28-2006, 06:23 PM
  2. Help with RR & Mappoint
    By pyros in forum Road Runner
    Last Post: 09-18-2006, 10:50 PM
  3. RR + Mappoint 04 Not workin?
    By IntellaWorks in forum Road Runner
    Last Post: 07-13-2006, 11:19 AM
  4. Replies: 4
    Last Post: 08-05-2005, 04:43 PM
  5. RR 3-30-05 ... Mappoint ...
    By guino in forum Road Runner
    Last Post: 04-06-2005, 01:47 AM
