Results 1 to 8 of 8
Thread: F-R fade problem
    Apr 2006
    F-R fade problem
    Hi, I have my PC setup with RR running Winamp 2.95 and using a D-link Radio. I am running 6 speaker setup without the centre speaker (so 5)
    All goes through the amps in the car.
    I have a F-R fade imbalance.
    Playing the Radio I can have (on the MB sound mixer) the front and rear up full volume but when playing MP3's through winamp the front is massively biased I have to turn the front speakers down to 25-30% to even it out!
    Is there any settings in Winamp which can control this?
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    What are you running for a sound card?
    As a simple solution you could just tweak the amp gains.
    Apr 2006
    Tweeking the amp gains would not solve the problem, if I set the amp gains to balance the F-R fade playing MP3's it will be out on the radio! If you see my dilemma!
    Apr 2006
    Oh it's built in sound up to 7.1 capable. tried it on 4 speaker, it's just the same.
    Jun 2007
    Quote Originally Posted by Nygie View Post
    My reading comprehension sucks today.
    I'm sure there's a way to do it with an autoit script where it switches your fade in the radio screen and then back to normal otherwise.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Try adding something along these lines:
    exectbl.ini
    "Radiofade","SETVOL;FRONT;70||SETVOL;REAR;30"
    "Musicfade","SETVOL;FRONT;30||SETVOL;REAR;70"
    Then add the "Radiofade" cmd to the end of the button cmd that loads the radio...ie
    b,xx,x,x,xxx,xx,x,x,x,"load;radio.skin||Radiofade",""
    Then do the same for the exit button on the radio screen...ie
    b,xx,x,x,xxx,xx,x,x,x,"Main||musicfade",""
    Should work, just tweek the values as needed...
    Enjoy!
    Current Project: DFXVoice [Beta Released]
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Apr 2006
    Thanks Blue, I'll give it a whirl.
    dme
    dme is offline
    Jan 2008
    finland
    I have a problem concerning front-rear balance, so im loaning this thread :P
    I have a 4 speaker setup on my car. I want to chance front-back balance bepending how many people there is in the car. I don't like to use backspeakers if theres nobody sitting there.
    And the problem is i can't adjust balance directly from master volume. I have to adjust balance from Master Volume->Options->Properties->Other->Multi Channel. Attached picture isn't from my car so you cant really see it, but you can see what i mean. So what slidercodes should i use in my mixer skin to change those values in that window? Or is it even possible?
    Hope you understand what i mean
  1. Lilliput TouchKit problem solved!
    By AAVfReaK in forum LCD/Display
    Last Post: 11-07-2010, 09:29 AM
  2. gps navilock and com problem
    By lele67 in forum GPS
    Last Post: 04-01-2006, 08:41 PM
  3. RR skins with F/R Volume Fade?
    By Willuz in forum Road Runner
    Last Post: 03-29-2006, 12:25 AM
  4. Problem with directshow filter and WMP
    By EricE in forum Software & Software Development
    Last Post: 03-01-2006, 11:38 AM
  5. Car Idle - power/amp problem?
    By TheFaze in forum Car Audio
    Last Post: 12-16-2005, 12:10 AM
