go into the rr.ini file and delete the audio = line or go into the config and make sure that the file extensions of your songs are selected. This should fix your prolblems as long as you have your winamp directory entered correctly in the config and that your winamp is capable of playing those files.
If they are APL or WMA files you need to dl plug-ins for winamp to be able to play them.
LinkBack URL
About LinkBacks
