Results 1 to 7 of 7
Thread: Retreiving Custom SLider value help needed
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Question Retreiving Custom SLider value help needed
    I am working on a script, that I need to get the slider value sent to. I have read there is a way to set a slider, then press a button, to get value of where the slider is.
    If this were the way a volume slider worked, you would need to put the slider where you want, and then press a button to actually change the volume.
    I am looking to do this in one step. Move the slider to the center for instance, and RR sends/stores a 50% command (or 0 to 255 whatever, I can have the script EVAL the range to get the correct value I need). I just need to then read that value after the slider has been moved without an extra "set" button to do it. Does anyone know of a way to do this?
    My Fiero Build Thread
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    In ExecTBL.ini,
    "ONSLD<SLIDERVARNAME>","SENDMSG;<your script>;<cmd>"
    Where <SLIDERVARNAME> is the CL slider var name. "ONSLD<SLIDERVARNAME>" is executed everytime you adjust the CL slider.
    You can then tell your script to read the raw value of <SLIDERVARNAME> and evaluate it w/in the script.
    EDIT: If you're just creating a custom VOLUME slider, the raw slider value can be evaluated w/in rr w/o the need of an external script:
    Skin Custom Slider:
    Code:
    S03,...,H,03,"slider2.gif",30,"$RAWVOLUMEVAR$",""
    ExecTBL.ini
    Code:
    "ONSLDRAWVOLUMEVAR","SETVOLUME;<LINE>;$RAWVOLUMEVAR$"
    I think that might work...*shrugs*
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Thanks! I will give it a shot now.
    Actually, hahaha this is not for volume control..... Its to dim lights in the living room
    EDIT:
    Ok, I am pretty sure I have the exectbl.ini correct. What I am unsure of is the skin code. In your above example, I do not see where the slider name goes:
    Code:
    I also have to pass 2 variables with the skin command(slider pressed), the device to control and the level to set it at. something like $device$ $dimlevel$. (The Device is hard coded, but the slider var needs to report where the slider is)
    I have a vbscript that reads the 2 parameters passed to it. It then in turn sends that command over the network to the home automation server to carry out the command.
    This is what I have in the exectbl.ini:
    Code:
    "ONSLD","RUNQW;wscript.exe" "$SkinPath$\scripts\vb.vbs|$device$ $dimlevel$"
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    "ONSLD" needs the variable name after... like "ONSLDRAWVOLUMEVAR"..
    Ride Runner RR's Myspace
    Jul 2007
    South Bend, Indiana
    [QUOTE=JohnWPB;1178580]Thanks! I will give it a shot now.
    snip
    I only hope that means there will be an x-10 skin in DFX 3. I'm keeping my fingers crossed.
    Aug 2006
    Sun Diego
    Quote Originally Posted by JohnWPB View Post
    EDIT:
    Code:
    In the case above, the slider name is the variable $RAWVOLUMEVAR$
    Code:
    The slider above can only pass one numerical value that ranges from 0-65535, which is stored in the variable $RAWVOLUMEVAR$. To be able to pass 2 variables, you'll probably need two sliders, use a BYVAR command, or use and EVAL function if the variables are related somehow.
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Thanks for the help, I have it almost all working with the above code.
  1. Suburban - Custom console carputer - W/Pics
    By rcracerx in forum Show off your project
    Last Post: 06-14-2007, 01:36 PM
  2. Epia-M custom Bios & entertainment module. Bios chip # needed.
    By v1s in forum General Hardware Discussion
    Last Post: 11-22-2006, 08:33 PM
  3. Trouble setting custom resolutions....
    By SinnerG in forum LCD/Display
    Last Post: 06-18-2003, 07:15 AM
  4. X-MP3Pad: Beta testers needed... Please read!
    By PorscheMP3 in forum Software & Software Development
    Last Post: 08-22-2002, 11:55 AM
