Results 1 to 3 of 3
Thread: Winamp skipping and stuttering... fixed
    Dec 2006
    College Park MD USA
    I didn't find any thread with this exact problem here, so here's the short version: I fixed my WinAMP (and other players too) skipping and stutter problem by disabling the wireless connection, which is a Belkin 802.11g PCI card.
    The long version is that there were spikes in CPU usage from a base of about 5-10% to about 40-50% and that's when the audio would stutter. Other things I tried, but which didn't work:
    -Reduce and Turn off Hardware Acceleration for audio device
    -Kill all unnecessary processes (wupdate, touchscreen, GPS serial emulator, Bluetooth, rundll32, etc.)
    -Increase Winamp buffer to 10MB (whole song)
    -Reduce Winamp quality to Half.
    -Set WinAMP priority to Realtime.
    I read somewhere else that disabling the WiFi card worked for someone, and sure enough that did the trick. Now CPU usage stays at about 2-5% flat for the whole song, and more importantly the audio doesn't stutter anymore. The WiFi connection is just set to Disabled, so I can enable it just fine if I need it. I don't know if it's a Belkin driver or Windows XP's Zero Configuration hunting for a signal (might be helped with WiFi Hopper) or what but it's just another annoyance.
    Specs: PC Chips M863G, 1.2GHz AMD Mobile Duron, 256MB DDR SDRAM, WD400 40Gb HDD, Belkin 802.11g WiFi PCI (disabled), SBO2 Touchscreen, Belkin USB Bluetooth dongle, Earthmate LT-20 USB GPS, M2-ATX HV power supply.
    Elantra GT 1.2GHz Duron, RoadRunner & LSX Void 3.2. Status: Stable...
    Constant Bitrate the_crooked_toe's Avatar
    Jul 2007
    Louisville, KY
    Quote Originally Posted by cobase View Post
    ya i know pretty crazy. I had to do the same thing a while back to get my music from stop skipping. I'm sure it's Windows Zero Config causing the problem hunting for a signal. I placed a shortcut on my desktop so i could easily turn back on the wireless whenever I needed to update the weather or anything of that sorts. glad u got it figured out
    Variable Bitrate Arrow's Avatar
    Feb 2006
    West Lafayette, IN
    I noticed the same problem after installing some wardriving stuff. I think it was WinPcap that did it. I did a driver rollback and the problem went away. So did WinPcap
  1. music stuttering when resuming from standby
    By dyne in forum Road Runner
    Last Post: 09-14-2006, 01:40 PM
