Results 1 to 7 of 7
Thread: When Jumping From One Screen To Another..
    Dec 2007
    is it closing(unloading) the current screen before the jump, or leave it on(stay in memory?) and switching to another screen?
    What's the most efficient way of dealing with this when switching from one another given the fact that my pc has bare minimum horse power.. Or hardly it takes any memory/cpu at all...
    I just discovered that when closing a screen, "EXIT" is better command to use than "CLOSE" or am i saying it wrong?
    Thanks..
    THE EXPERIMENTER
    carputer1's Avatar
    Sep 2007
    UK,Surrey
    you can use this
    Quote Originally Posted by brandensin View Post
    Thanks..
    in each skin you don't want held in the memory
    /DISCARDABLE
    If the above is found in a .skin file, RR will unload that skin file once you navigate away from it.
    This can be useful to keep memory clean and to force reloading of objects of a screen.
    Riderunner / Genesis
    Wifiman_NET:Version 1.0.0
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    "bare minimum horsepower"....are you short on memory or cpu processing power? Usually on a low spec computer preloading screens into memory when RR starts and keeping them in memory speeds things up--the additional memory usage is small. Background running tasks and services in Windows can make the difference on a low spec computer.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    Dec 2007
    So, what should i use? close||load? exit||load ? or just load?
    Oct 2006
    small town nebraska
    Just Load--that will "load" the next screen (from memory if possible, or from file it's it's not in memory yet).
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    Dec 2007
    thanks.. will do..^^
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    You don't have to add /DISCARDABLE to every screen (while this could work), you can simply set the screenlimit to a low number like 3 or something (minimun is 3 - 1 for main menu, another for a new screen to be loaded and another to provide support to a possibly opened menu).
    Ride Runner RR's Myspace
  1. Replies: 28
    Last Post: 01-30-2011, 01:33 PM
  2. Replies: 14
    Last Post: 09-11-2008, 03:14 PM
  3. Digital FX 2.0 Transparent Released
    By JohnWPB in forum RR Skins No Longer Supported
    Last Post: 03-07-2008, 12:23 PM
  4. Constantly removing the screen 7" lilliput advice
    By steveb in forum LCD/Display
    Last Post: 04-17-2007, 10:56 AM
  5. Cracked Touch Screen!
    By bmather9 in forum LCD/Display
    Last Post: 04-17-2007, 04:31 AM
