Results 1 to 7 of 7
Thread: i read faq on gps setup...but
    Dec 2007
    i am not sure if i understand clearly...
    the menu allow you to select only the ones defined in the rr config, right? anything not on that list can not be added to the menu, you kinda need to create you own menu(skin) for multiple gps choice, is that right guys?
    did i put it right way... let me try again..
    I read FAQ, it says i can either set it to run a specific gps or pop a menu to pick one i like to run... What i wanna know is if i can add other gps to that menu...
    Thanks for your help...
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Since that gps menu is skinnable, yes you can add other GPS apps with the appropriate button command.
    i.e.
    LOAD;EXTERNAL_GPS.skin;RUN;<gpspathandname>;<gpswi ndowname>
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Dec 2007
    Sal, thanks for your help... now, does this gps menu thing come with RR installation, or i need to make one for the skin i use? Another question is, once chosen, how would i get it to remember as a default?
    Aug 2006
    Sun Diego
    RR Readme.txt:
    gpsmode=3
    This sets the behavior of the GPS button/function.
    (0=Destinator, 1=Mappoint, 2=External, 3=Menu)
    The above is what is currently built into RR in terms of GPS options.
    The menu that comes w/ RR displays all the gps options:
    Destinator, Mappoint, External.
    You can add additional programs to the menu w/ the right button code. By default, RR won't remember your "default" GPS app if you selected the gpsmode=3 (menu option). You can add code to those buttons to make RR remember which GPS app you choose, but that's all up to you.
    If you're only running one GPS app you can set those options in rrconfig (path, name, window name) and RR will launch only that GPS app.
    Hope that helps.
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Teknik 1 has the code that remmembers which GPS you chose.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    The only time I run 2 gps app at the same time is iG and MS S&T. iG is the default GPS as setting in RR config so the GPS button will launch that automatically. MS S&T has it own button on the skin. Basically the GPS in the skin is like this.
    B00,X,Y,W,H,"GPS",@MSGPS@
    So if I press and hold the GPS button, it will load MS S&T.
    In ExectTBL.ini I defined MSGPS command similar to this.
    "MSGPS","LOAD;MS_GPS.skin;RUN;path-to-exe;gps-window-name"
    not the best but it work for my purpose.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2007
    Thank u and thank you... Now, i have a pretty good picture of what I need to do....
    by the way, have u guys checked out the new gps softwares... mainly igo8... That's one eye popping toy for sure... God.. this thing never ends....... on and on and on.. good and bad.. ^^
  1. FAQ: What is the best GPS software?
    By DarquePervert in forum The FAQ Emporium
    Last Post: 05-20-2011, 10:39 AM
  2. GlobalSat BT-338 Review
    By tom2112 in forum The Review Palace
    Last Post: 06-27-2005, 11:02 AM
  3. How fast of a computer needed for dual monitor (GPS & DVD) setup
    By mykolJay in forum General Hardware Discussion
    Last Post: 09-23-2004, 03:29 AM
