Results 1 to 8 of 8
Thread: Force Tag Display Refresh within roadrunner?
    Aug 2006
    Hi all,
    I need to load new music tracks via an external program on one screen of my skin, all works fine and loads up in winamp but when I look in RR it still displays the old tags from what I had in the playlist previously..
    I have partially solved this by automatically issuing 'ReloadListEx' when I make my new music selection but I only see the changes after the first track has played (or until I skip to the next track)
    Is there any command to force RR to reload the labels with the latest info without having to skip to the next track ?
    Cheers!
    Aug 2006
    bump
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Try RELOADLIST (without EX), try CLEARLIST||RELOADLIST(EX) etc... you should NEVER load music direct in winamp -- you should have RR load it for you so that it is updated both in winamp and RR.
    Ride Runner RR's Myspace
    Aug 2006
    Thanks Guino,
    I will try those out when I get home - I don't remember testing out CLEARLIST so hopefully that will do the trick
    Aug 2006
    Hi Guino,
    I have just tried your suggestion and CLEARLIST does exactly that.. clears the playlist
    So if I issue after loading my new tracks it stops all music and wipes winamp's playlist..
    RELOADLIST and RELOADLISTEX don't work - well, RELOADLISTEX does but it only updates the labels on my skin at the next track change.
    Is there any way to fool RR into thinking winamp has changed track after I've issued RELOADLISTEX so that it updates the skin labels straight away ?
    Cheers!
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I do not know why this works but it works, BlueZX3 was the one that told me about it.
    If you put a list in the screen that is not updating, it should then start to update for you. The list does not need to be visible , just make it 0 x 0 pixels like the below line:
    Code:
    S01,0,0,0,0,255,255,255,255,255,255,255,255,255,255,255,255,0,0,0,TRUE,20,"Arial Narrow:B"
    I did this on a couple of screens in my skin, that were getting information from outside RR, and it now updates perfectly on that skin.
    My Fiero Build Thread
    Aug 2006
    John you are a legend! That works a treat
    Strange as you say but at least it works!
    Thanks for the assistance guys
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yea, one of those oddities for sure, and definitely undocumented, but it does work
  1. V1 Virtual Display : Skinnable Valentine One to PC Software
    By zPilott in forum Software & Software Development
    Last Post: 01-18-2013, 06:11 PM
  2. frodo display help
    By turbocad6 in forum FrodoPlayer
    Last Post: 10-14-2005, 11:37 AM
  3. Display File Name instead of ID3 Tag?
    By MoonShiner in forum FrodoPlayer
    Last Post: 06-26-2004, 05:00 PM
  4. Any way to relocate my display card??
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 03-22-2004, 10:14 PM
  5. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 11:43 PM
