Results 1 to 10 of 14
Thread: will one of my RR bretheren help me out with configuring a visualization?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    I'm having fits about this cause i know its something simple but i just cant get it. I wish to get winamp to display ONE visualization- then spectrum analyser. I have that loaded and it plays like it should but then 10 seconds later it changes to another random visual. How to i make it so that spectrum analyzer stays put!
    Live mp3Car Facebook Chat
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    At least you can get your visuals working, mine always gives me screwy errors
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
    Dec 2007
    Sonic, run winamp by itself then options -- preference...
    ...visualization.... start... then configure
    once u see winamp avs editor, go to settings, presets/hotkeys... there, uncheck, "Randomly switch presets..." close... that's it... which visualization are you using?
    Woodbridge, VA
    Blog Entries
    55
    i'm using avs and that worked perfectly. i thought it had somthing to do with the transitions options .. never thought to look in the presets. THANK YOU
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    Just a note: You can also make a few colors of the spectrum analyzer by editing the color settings in the configuration and saving them. Then you can MANUALLY change them in Road Runner with the "NEXTAVS" and "PREVAVS" commands to cycle through different colors. I used the label exec code to place those buttons over the album art in my skin. Its a nice touch to be able to change the color to the users preference.
    My Fiero Build Thread
    Woodbridge, VA
    Blog Entries
    55
    i noticed that you have the files stored as a part of dfx, i'll have the check those out in greater detail when i get a second
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    Blog Entries
    1
    Yea, in the helper files folder. I made a spectrum analyzer in all the common colors, Red, Green, Blue, Orange, white ect.
    Just pop em in a sub-folder of the AVS/Plugins folder. Then in the same configuration mentioned above, you can tell it to just use visu's from just that sub folder. If you leave it on the root folder, you better feel like pressing the screen a couple hundred times to go through them all
    Raw Wave treetop777's Avatar
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by JohnWPB View Post
    Son-of-a-gun! That's what i was doing like a big dummy! Not anymore..THANKS.
    Dec 2007
    yeah.. i learned all that goodies from the Might John's DFX.. In fact i am learning so much from DFX and help file he compiled.. He also posted in FAQ section or his help file i think on optimizing VIS setting without loosing VIS performance but inhancing the CPU usage significantly... U might wanna check that out guys...
    Ok, guys,, found the link..
    http://www.mp3car.com/vbulletin/rr-f...ad-runner.html
    pay attention to #6....
    Sep 2006
    War-Town, GA.
    Quote Originally Posted by brandensin View Post
    Good info...
  1. RR Newb... need help/suggestions.
    By Nola111 in forum Road Runner
    Last Post: 03-12-2007, 08:10 PM
  2. RR Embedded IGuidance causes RR to lose focus
    By durwood in forum Road Runner
    Last Post: 11-10-2006, 10:31 AM
  3. Update resume.ini during RR execution?
    By tmar89 in forum Road Runner
    Last Post: 11-01-2006, 10:16 PM
  4. Generalized Perception of RR from a new user
    By replicant in forum Road Runner
    Last Post: 11-15-2005, 11:41 PM
  5. RR doesn't start Phoco on initial load..
    By DutchBurner in forum Road Runner
    Last Post: 11-04-2005, 02:17 PM
