Results 1 to 6 of 6
Thread: Auto Play DVD with MPC
    Nov 2006
    I have RR setup to use MPC. When I click DVD in RR I see the MPC open, but nohign happens. If I quit RR MPC is just sitting there open. How do I tell RR or MPC to start playing the DVD. I have a DVD in the drive.
    Do i need to enable something in the MPC.INI in the RR folder?
    Feb 2007
    netherlands
    to play dvd, you need codecs, if you have them and it stil doesn't work, use the bmv2 to test if it is a rr problem or not.
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    install the latest stable release of ffdshow and see if it works. Try getting a dvd to play with MPC outside of RR first.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    Jan 2007
    East Central FLA
    Info above is good advice.
    I can tell you that I built a simple skin for myself and to get the DVD to begin play when the DVD button was pressed, the DVD button had to be in the main menu. I have no idea what I had in the skin to make this true, but it was. The only way I could get a DVD to play from a DVD button on another menu was if I used a mouse and right clicked to bring up the MPC menu. Another thing to check would be that the button command is DVD and not video.
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    just make sure MPC can play your DVDs OUTSIDE RR -- open it and press CTRL+D -- if this doesnt work, then it wont work in RR either, but if it works, then it should play in RR as well. If you have multiple dvd drives, this could be a reason why MPC doesnt automatically find the DVD.
    Ride Runner RR's Myspace
    Variable Bitrate BREWDOG52's Avatar
    Aug 2007
    Oregon
    If you have a virtual drive setup, make sure it isn't listed before your physical drive like mine was. Also "DVD" doesn't have to be on main menu, my button is in video_player, works fine.
    or you should be able to open up MPC goto view-options--playback-dvd and select user defined path- enter your dvd drive letter ie. d:\
    Most important thing is that it can play your dvds outside of RR like Guino said.
  1. Play DVD
    By SUNAJ in forum Centrafuse
    Last Post: 01-29-2007, 07:30 PM
  2. dvd auto play on disc insertion...
    By Hell-Stopper in forum Road Runner
    Last Post: 01-16-2006, 08:11 AM
