Results 1 to 7 of 7
Thread: Using more than one launch.skin
    Jun 2007
    Hi,
    I am using a launch.skin to embedd some external utilities and I would like to use more launch skins (with different folders). The idea is to have a launchGamesPC.skin, launchUtilities.skin, launchEmulators.skin, etc.
    I think that I must use a dir list with SXX and then use some SD options to make road runner knows that is a launch folder.
    How could I do this??
    Thanks!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    read about variable and the custom list feature in skin commands.txt
    Live mp3Car Facebook Chat
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    Yes, you'd have to build a custom list and use variables to help you with that. Or you'd have to do some tricky renaming of files/folders along with /discardable in the .skin to make RR reload different copies of your launch.skin (using the same file name)
    Ride Runner RR's Myspace
    Jun 2007
    I am trying to use "SETVAR;launchpath;$skinpath$launchGamesPC||LOAD;l aunch.skin" and
    "SETVAR;launchpath;$skinpath$launchUtil||LOAD;laun ch.skin" but it seems that variable cant be changed in runtime.
    Writing the launch path to rr.ini (SAVETOINI) and reloading road runner works, but I would like doing this without having to write the .ini file in the hard disk or renaming the launch folders (I would like to use road runner in a non writable ewf+horm system).
    Any ideas??
    Road Runner only interprets folders lists like launch list if they are in the launch.skin??
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    You could always write a script to rename the separate launch folders to "LAUNCH" prior to loading LAUNCH.skin.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Jun 2007
    Thanks to all, finally I resolved this using 3 custom lists (for each launch list) and switching between them to load the application path and window name into road runner variables. The code line I used is:
    B,517,398,275,116,"SETVARBYCODE;POS;CLPOS||CLCLEAR ||CLLOAD;$skinpath$Listas\JuegosPC_path.txt;true|| SETVARBYCODE;PATH;CLTEXT$POS$||CLCLEAR||CLLOAD;$sk inpath$Listas\JuegosPC_ventana.txt;true||SETVARBYC ODE;VENTANA;CLTEXT$POS$||CLCLEAR||CLLOAD;$skinpath $Listas\JuegosPC.txt;true||LOAD;EXTAPP.SKIN;EXTAPP ;$PATH$;$VENTANA$",
    And it works!!
    Woodbridge, VA
    Blog Entries
    55
    good to hear you've solved the problem. The custom lists were just recently added and they are a HUGE addition to Road Runner's abilities. Using custom lists and a simple autoit script i was able to make a file manager that runs directly from within RR.
