Results 1 to 10 of 12
Thread: GPS date/time sync behavior
    May 2004
    I'm planning to use the GPS date/time sync feature in RR on a CarPC that's always in standby or hibernate and both RR and Navi software always running at the same time.
    How does RR schedule time/date sync? Will it sync coming out of standby/hibernate?
    Do I need a serial port splitter (i.e. GpsGate) to have both RR sync feature and Navi software running in parallel? The failure mode would be PC coming out of standby with both RR and Navi SW running, Navi grabs the com port, then RR trys to sync and fails to open port or vice versa.
    On a related topic, the volume control via GPS speed: Does RR also need constant access to the com port?
    Thanks,
    Bryan
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    I have had issues with the GPS date/time sync. It caused my clock to go wonky a few times and it set the time wrong.
    You will definitely need a port splitter, otherwise RR will lock out the port you select for it and your navi software won't work. GPSGate is a good choice, I perfer it to Xport. Xport is free though, so that's a consideration.
    The GPS speed volume control does not need access to the com port, that's based on IGuidance sending wav data and RR picks that up.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    Quote Originally Posted by Machinehead View Post
    The ability for this to work correctly has a lot to do with the brand of GPS antenna that you are using. There is supposed to be a standard gps string format that its supposed to send to the comp but after guino added the feature, found that different ones send out the date/time in different formats. Which makes this feature a hit/miss kinda one.
    I'll second that XPort recommendation!
    Just FYI, the GPS speed vol( GPS Speed Att) actually uses the data from RR's com port, as do some other of RR's built in GPS type featues..
    Next in line: RRMedia v2.0
    DFX 5.1.1 Skin
    Appstore Link
    My RideRunner Plugins
    RRMedia
    RRExtended
    DFXVoice
    Jun 2007
    You would definitely know better than I. Thanks for catching my mistake.
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Make sure you get all the windows updates if you're an hour off right now. I think KB942763 fixed the DST change.
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    M$ updates... We don't need no stink'n updates...
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Super Moderator
    JohnWPB's Avatar
    Sep 2005
    West Palm Beach, Florida
    Blog Entries
    1
    I personally do not recommend setting RR to set the time via GPS. I had done this at one time and it set it like months off from the correct date and time! I have seen many many reports of this. This is not really a RR problem, but the way the GPS does not have a "good enough lock" even though it appears to, and sets the time with what it has, as incorrect as it may be.
    My Fiero Build Thread
    May 2004
    Thanks guys, so it seems that the RR time/date can have some irregularities. Shouldn't RR look at other NMEA sentences to verify proper satellite lock before updating?
    The Curator
    Blue ZX3's Avatar
    Aug 2004
    Chicago area,IL
    That could be the problem too. If I'm correct, RR has to see at least 3 sats locked before it will assume incoming gps data is good.
    DFX 5.1.1 Skin
    Appstore Link
    RRMedia
    RRExtended
    DFXVoice
    Maximum Bitrate redls1bird's Avatar
    Feb 2006
    Atlanta Ga.
    Quote Originally Posted by JohnWPB View Post
    I had the exact same experience. I want to say it was like 4 months off.
    Car Pc progress meter:
    [-5%-------------------] Carpc build #2. So far, 20$ deep! I love recycling!
    "The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
    My worklog
  1. Replies: 353
    Last Post: 08-24-2009, 10:31 AM
  2. PPC Car GPS and MP3 mini How To
    By hotrod_nut in forum General Hardware Discussion
    Last Post: 02-25-2008, 02:24 PM
  3. SD Navigation just does not work.
    By rumy in forum StreetDeck
    Last Post: 03-10-2007, 08:11 AM
  4. few gps questions
    By fuctup in forum GPS
    Last Post: 03-02-2005, 02:40 AM
