Results 1 to 7 of 7
Thread: using gps.. can't switch back to music.. ?
    May 2006
    I've noticed that I can't jump between gps and the mp3 player.. and I've also noticed that searching sometimes locks up rr...
    Im using iguidance.. so, when I choose it, I have to close it to go back to the music player..
    what's up ?
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    What skin?
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    May 2006
    using the alpine skin...
    Jan 2007
    East Central FLA
    I have no experience with the Alpine skin, but can assure you that this is not a Roadrunner limitation. I switch back and forth all the time when I'm out on the road.
    One thing that should be easy to check would be to open the Alpine skin in the skineditor and see what commands are assigned to the various buttons. If there's one labeled AUDIO on the gps screen it 'should' switch over to music without having to exit iGuidance, then the audio screen should have one labeled for however you start iGuidance, i.e., GPS.
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    open your rr.ini and change ignative=false and see if that stops the problem. You probably have the famous wav bug
    Live mp3Car Facebook Chat
    May 2006
    yah my alpine skin uses the "external" skin and there is only a close and exit button..
    Dec 2007
    u need to add a button on the external skin with a command, "audio" or u can use navimon, which will do the automatic switching and voluming.. plugin forum, search for navimon.... It works very well...
  1. Lower music when GPS is speaking?
    By elvis98 in forum StreetDeck
    Last Post: 03-01-2007, 06:48 PM
  2. Getting Started with GPS
    By grepzen in forum The FAQ Emporium
    Last Post: 09-26-2006, 06:54 AM
  3. Switch between music and media library w/ keyboard?
    By adamis in forum Media Engine
    Last Post: 10-12-2005, 10:29 AM
