Results 1 to 8 of 8
Thread: How do you work this configuration?
    Apr 2005
    I have been reading the faq's and can't seem to figure this out. Someone point me in the right direction.
    I downloaded the RR install, RR skin installer, RR skin editor and crystalblue skin. I open the config on the RR install under the program files, select my skin and when I start road runner it just displays one image and doesn't change, no little pics, no characters.
    Do I have to load each page, and if so how do i do this?
    Apr 2005
    I tried the skin installer and its says install failed.
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    Hard to diagnose the problem at this point. Your description is too general.
    Go to your Road Runner folder, open rr.ini in notepad, copy/paste the contents, and post it up.
    That'll help us help you.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Apr 2005
    Well I got it to work. Thanks
    Now if I want to edit the skin, say for example someone's skin I dled has radio, dvd, video etc etc and I want to change the words around how do I do that? I tried in the skin editor but can't find the file with the words.
    Variable Bitrate john05srt4's Avatar
    Oct 2006
    Florida
    Yea Mazdaboy.. ive been tyring to edit a few myself.. Theres always buttons i dont want and would liek to edit but many of the good skins are flash so basically i think you can just edit the button very easily..
    But hopefully im wrong..
    10 acura TL tech
    10 BMW S1000RR
    Variable Bitrate chevyn8's Avatar
    Oct 2006
    small town nebraska
    A good skin to play around with would be DigitalFX 3.0.....as you can change the buttons around easily. Press and hold, then choose the command you want the button to become. Also shock v6.1.1...just one file to edit--settings.txt.
    CarPC in my 82 Camaro. Dual core atom, M4-ATX, 7 lilliput, bu353 GPS, Reborn skin, punch 40/100ix
    MediaLaunch for RR
    Online Check for RR
    Locker for RR
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Different skinners will design the graphics for their skin differently. You get a better finish by including the button text in the graphic, but its more difficult for people to change the graphic. RR has the facility to use labels, and some skinners have a blank graphics button, and then use labels for the text. This is far easier for people to edit, as they only have to change the text in the label, and then the function of the button using skin editor.
    As a reference skin Digital FX is probably one of the most complete, and changeable out there, and should certainly be downloaded as a reference skin to understand some of the inner workings of what you can do with RR.
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Apr 2005
    I dled the digital fx 3.0 and have been playing with it. I selected a different color and the clock in the center still stays the same, it won't change to the mitsu symbol. How do I change it?
    Also how do I make my own shortcut. Say I want to run dsmlink for my dsm how do I add the text and set the exe file?
  1. How to make Winamp TV Plugin work with RR
    By ramez75 in forum Road Runner
    Last Post: 09-03-2010, 01:17 AM
  2. Stealthy surfing at work?
    By e_z_street in forum Off Topic
    Last Post: 10-07-2009, 03:30 AM
  3. Does FluxMedia own rights to our skins?
    By justintime in forum CF Skins
    Last Post: 09-03-2006, 08:22 PM
  4. Prison vs Work
    By ACHIEVER in forum Off Topic
    Last Post: 04-15-2005, 02:53 PM
  5. Replies: 4
    Last Post: 11-18-2002, 09:59 PM
