Results 1 to 4 of 4
Thread: display position offset when running RR
    Apr 2007
    Washington, DC
    I have an issue where inside windows running 800x600 everything looks fine on the desktop and is centered correctly. Once i launch RR, the screen offsets by about 150 pixels to the right, vertical spacing is ok. The weird thing is that this system has been running for several months and no config or updates have taken place. It just started doing this today. I have looked thru the gen.ini all the x and y positions are at 0. All skins do this, i have tried 3 so far. RR is the only program that does this, any ideas? Any temp files that store the last x position might have been corrupted?
    Dec 2006
    try this.
    back up your skin folder. Change display in RR Config to default. Go in your skin folder in Main or general.ini - forgot which one- where it says show height= change to 1024 show width= 768 .... See if that helps
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    If it looks fine in XP, it should look fine in RR as well -- unless you have set RR to change the display resolution. Open RR.INI and delete the resolution= line from it, then try again.
    Ride Runner RR's Myspace
    Apr 2007
    Washington, DC
    removing the resolution line sorted it. weird thing is that it has been there since day one, go figure. Thanks!
  1. REQUEST: Run Multiple RR instances
    By Jarrod in forum Road Runner
    Last Post: 12-21-2008, 08:54 AM
  2. RR Interchange - Update RR via a USB Media Stick
    By Gobby in forum Road Runner
    Last Post: 10-04-2005, 05:48 PM
  3. status update....
    By 0l33l in forum PowerVoice
    Last Post: 05-05-2005, 01:22 PM
  4. RR fails to load / vis display glitch
    By RhinoT16S in forum RR Bug Tracker
    Last Post: 02-23-2005, 09:14 PM
  5. Replies: 4
    Last Post: 03-07-2004, 02:01 AM
