Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
Thread: RoadRunner And Powermate?
    Feb 2007
    I'm trying to figure out how to get my powermate to work in roadrunner. I've searched and still can't figure it out. I've imported this .gnl file into the girder program I downloaded.
    How to use Girder with Road Runner
    I'm not really sure what else has to be done. Is there a step by step tutorial somewhere? I'm using girder 3.3 and lsxvoid 3.2
    Thanks!
    Kyle
    FLAC -zip-'s Avatar
    Ontario/Canada
    Do you have the powermate plugin for Girder installed?
    Also have you read on Girders website how to remove/deactivate the original Powermate software from loading on Windows start up but leaving the driver installed?
    Sound Stage
    Eclipse|MTX|Infinity
    Feb 2007
    I have the powermate plugin installed into the girder plugin folder, but I'm not sure if it is enabled or not. I didn't know you had to deactivate the original software but I'll do that when I get home from work and see if I'm any further along. Thanks
    kyle
    FLAC -zip-'s Avatar
    Ontario/Canada
    you can check to see if the plug in is working properly under File.. Settings/Plugins.
    Scroll down to the Powermate plug in. If its working it will be green. While there auto enable the device with a checkmark on the same screen.
    Sound Stage
    Feb 2007
    Ok the powermate plugin is checkmaked but it is highlighted in red. It says "Plugin is loaded in memory but hardware intulation failed". I deactivated powermate.exe fom startup through regedit.
    Feb 2007
    any thoughts on why I'm having the problem?
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    What do you want the powermate to control?
    Volume is an original global setting, you can alo define send keys in the powermate's program.
    Leonardo Da Vinci
    Feb 2007
    Quote Originally Posted by greatwhite View Post
    yes that is how i have used my powermate to control road runner. I added the following to KeyTBL.ini and then in powermate setup assigned the key strokes. This gives volume control, next/previous track, switch to plays list directory or audio player (just my choice - you can do what suits your usage)
    37,"RRPREV"
    39,"RRNEXT"
    9,"LIST||BACK"
    45,"AUDIO"
    Feb 2007
    I would like to be able to:
    -adjust the volume + mute
    -scroll through the songs + select artist to play or individual song to play
    -next song or previous song
    -Possibly navigate the main menu if possible
    I was thinking:
    -left turn, right turn for the volume
    -single click to mute/ unmute
    -click and turn to scroll through songs
    -long click to select song/cd/artist
    Any help would be awsome. Thanks!
    Kyle
    May 2007
    Your first two desires for vol and mute are the way it comes from the factory for windows.
    The next two is just a matter of finding the correct "sendkeys" would think......
    Leonardo Da Vinci
  1. 2000 Mitsubishi Verada Car PC Install
    By MitchellO in forum Show off your project
    Last Post: 01-08-2010, 07:09 AM
  2. Griffin Airclick and powermate plugin
    By rumy in forum StreetDeck
    Last Post: 07-26-2008, 12:23 PM
  3. Powermate Interface for Roadrunner
    By quickmic in forum Input Devices
    Last Post: 07-21-2007, 08:34 AM
  4. PowerMate & scroll address help
    By zx16v in forum Input Devices
    Last Post: 10-04-2006, 07:54 AM
