Results 1 to 6 of 6
Thread: Any Fix For Volume?
    Low Bitrate BLAXKINNED's Avatar
    Jan 2007
    OakLaHoeMah
    Any Fix For Volume?
    I have been using RR for about a year now, and it's the best hands down becos it's got more pros than cons.
    The one problem I seem to have and pardon me if the solution is posted somewhere here (I searched and read thru trillions of threads but couldn't find it) - is there a fix for the volume in ROad Runner.
    When I start the application, I cannot adjust the volume until I first mute it then it lets me increase or decrease the volume.
    I would appreciate any positive inputs.
    Maximum Bitrate tundra2000's Avatar
    Mar 2006
    Houston, TX
    you could just put MUTE in your start up commands (in RR.ini). other than that, i havent heard of a problem like taht. for whatever reason, you are starting up in MUTE mode, idn.....
    MGD
    MGD is offline
    MGD's Avatar
    Feb 2005
    Los Angeles
    Quote Originally Posted by BLAXKINNED View Post
    You have your 3 stage mute button active. Run the RRConfig.exe and under speed att vol, uncheck "Adjust volume based on GPS Speed" that should let you adjust the volume right away.
    Jan 2007
    OakLaHoeMah
    Ok thanks folks...I'll try ur suggestions.
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    I don't want to jack this thread, but i figured i'd add my own RR Audio problem to this thread. For some reason my WAVE changes based on the bitrate of a song. If you play something thats 320kbps it goes to 0. Sometimes you click on a list item to play a song and there is no audio until i go into the mixer and adjust it manually. This is really driving me insane. Any input??
    Dec 2004
    Staten Island, NY
    bump! does anyone have any idea about this issue?
  1. Replies: 8
    Last Post: 08-27-2010, 03:26 PM
  2. Has Yahoo Launchcast problem been fix
    By tn6478 in forum StreetDeck
    Last Post: 11-09-2006, 11:14 PM
  3. Neocar External Application Bug Fix!
    By reddeath30 in forum NeoCar Media Center
    Last Post: 04-07-2005, 09:25 AM
  4. Think I foubd BUG with map monkey and media car
    By cdevelasco in forum MM Bugs
    Last Post: 02-02-2005, 10:52 PM
  5. Palm Battery drain fix
    By Loftus in forum General Hardware Discussion
    Last Post: 05-01-2002, 09:57 AM
