Results 1 to 4 of 4
Thread: Weird problem with USB sound card
    Sep 2006
    Richmond, Tx: USA
    Recently my sound card (on mobo) started acting up so I decided to reinstall my Phillips PSC805 Aurilium USB External Sound Card. As soon as I installed it, for some reason everything started crawling. I am using Digital Fx 3.0 and as soon it starts my CPU goes 100%.
    I uninstalled the Philips software and used the default USB sound card driver in XP but same result. Outside RR, everything works fine so I'm not sure what's causing the CPU to go 100% as soon as RR starts. Before installing the sound card, everything was working fine.
    I've already tried RR setting of mapping sound to "all lines" and "master vol" but nothing changed
    Any idea ?
    Sep 2006
    Richmond, Tx: USA
    Anyone ?????
    RoadRunner Mastermind
    guino's Avatar
    Nov 2004
    Toronto, Canada
    did you disable the built-in sound card? chances are the drivers/files you loaded overwrote something previously installed.
    Ride Runner RR's Myspace
    Mar 2006
    Yea, i had the same problem a couple months ago. It was the driver like guino said. I uninstalled the onboard driver and then disabled it through the BIOS.
  1. USB Sound Problem
    By blafrisch in forum General Hardware Discussion
    Last Post: 08-29-2007, 11:01 PM
  2. usb sound card recommendations
    By aletchet in forum General MP3Car Discussion
    Last Post: 11-29-2006, 09:34 AM
  3. Audigy 2 NX Sound Card USB Problem
    By bl3nd3r in forum General Hardware Discussion
    Last Post: 06-22-2006, 06:01 AM
  4. Sound card vs USB card
    By Splinter in forum General Hardware Discussion
    Last Post: 09-06-2005, 11:49 AM
  5. Replies: 5
    Last Post: 02-03-2005, 02:43 PM
