Results 1 to 7 of 7
Thread: audio playlist to pendrive??
    Jun 2007
    Hi,
    Do anyone know a plugin or a sequence of RR commands to copy all the mp3 files of the actual playlist to a flash memory??
    I think it could be useful to copy the songs with one button in the audio player skin...
    Thanks!!
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    it would have to be done in autoit.. but i can see it being a pretty simple process. I'm sure bluezx3 or some other autoitpro will whip up a script for ya.
    Live mp3Car Facebook Chat
    FLAC Sal R.'s Avatar
    Aug 2006
    Sun Diego
    My MMIv2 skin has that feature, but first, you need to set up the drive paths to your pen drive under the "Setup" >> "Media" menu.
    After you've loaded your playlist, go to "Playlists" >> "Copy Playlist Contents," then select the media you want to copy the playlist contents to.
    I'd post up the script for you, but the DL link is blocked here at work.
    Pico-ITX / XP Home with EWF-HORM / RR v12/02/2009 / Winamp v5.13 / RRMedia v1.2.2
    Constant Bitrate spidermunz's Avatar
    Dec 2006
    italy, sardinia
    ops... sorry!!!
    my solution not resove the problem
    EL CAMINO's Avatar
    Jul 2005
    upland california us
    i made a script for that some time ago, can copy currently playing song, the playlist or the folder where the playing song is.but give a try sal's solution his might be more updated than mine, mine is a bit old.
    Aug 2006
    Sun Diego
    Try this:
    1. Add this command to your ExecTBL.ini:
    Code:
    "SENDPLAYLIST","SAVELIST;$skinpath$.\temp.m3u||RUN;$skinpath$copyplaylist.exe"
    2. Drop the .exe into your skin's folder.
    3. Define "$destinationmedia$" via rr.ini, skin.ini or "SETVAR"
    i.e.
    destinationmedia=E:\ or SETVAR;destinationmedia;E:\
    *Don't forget the trailing back slash.
    4. Run "SENDPLAYLIST"
    That should do it...I think...
    Attached Files Attached Files
    Jun 2007
    Thanks to all, now I am near of finishing the skin. When finished I will release it, because I think that it is more yours that mine (this great forum gave me all the ideas and help I needed),
    THANKS!!
  1. Playlist Converter Released for RR
    By SangreDeThor in forum Road Runner
    Last Post: 02-21-2009, 01:19 AM
  2. Playlist Browsing Bug
    By Sal R. in forum RR Bug Tracker
    Last Post: 03-30-2008, 05:00 PM
  3. Replies: 9
    Last Post: 01-18-2008, 08:33 PM
  4. Audio problems, Epia Sound, and FAQ stuff
    By gothate in forum Newbie
    Last Post: 06-16-2005, 05:04 PM
  5. Media car audio playlist
    By Walkman2001 in forum MediaCar
    Last Post: 09-24-2004, 06:52 PM
